This is my track setup, for the street I plan to get some proper offset/sized BBS
I dont think its that easy of a fix. While the lower control arm do space the wheel out. It was my understanding that they also throw some other geometry off which requires even more parts to correct.
Just repeating what I read on another thread here. Im not sure if increasing negative camber AND increasing front track width is possible with these but Im sure Elephant Racing could answer that. I guess for full control adjustable front control arms would be the way to go.
The front of the 9X1 are pretty simple, there are (4) connecting points, the top of the strut, the thrust arm, steering arm and the lower control arm. If you were to put in the offset lower bushing in the lower control arms you would also want to install a caster bushing in the lower control arm or you would likely have too much caster, 10-11 deg. It is not required, I have run my car with excessive caster for a while now and 99% of drivers would never notice the change. That being said the camber should be fine with the factory strut adjustment and you should have no issues with the steering rack geometry unless you lower the car. If lowering the car beyond the SPASM ride height you may want to look at purchasing an "Bump Steer" tie rod kit to correct the steering arm geometry though this should only be done by a professional with a Bump Steer Gauge Set.
So back to the main point, moving the lower control arm out has very little effect on the suspension geometry, however changing the ride height has a very large impact in comparison.
