Brake caliper bleeder screw size?
Does anyone know the brake caliper bleeder screw size? Looks like I have one that's clogged or having issues as it won't bleed fluid. Can't find it one Suncoast, Pelican, etc.
Thanks in advance.
Thanks in advance.
If you need the full bleeder don't try to find it at the auto parts store. The seat type and angle are critical. Remove the bleeder from the caliper and ensure its clean. Just get ready to bleed that side and use a towel to capture dripping.
The wrench size on most porsche bleeders is 11mm. Use a 6pt wrench or a line wrench, a GOOD one. You don't want to use an open ended wrench on bleeders unless you like rounded off bolts.
The bleeder itself will be one of these parts depending on your car spec:
997 352 919 00
8A0 615 273
997 352 919 00
8A0 615 273
