Targa Headliner Failure
#31
Hang in there Wes. It’s of little comfort that you’re the only one to report a problem, but **** does happen. More importantly is how they take care of you, including extending the warranty on your top. I’d start lobbying for it now rather than later.
DaveGee
DaveGee
#32
That is actually a good suggestion, I will bring it up today and see what happens. I was going to also ask if they (and they should) have a data base of failure rates and MTBF (mean time between failures) of parts and what that looks like from a model year. I am not sure they would be willing to share the MTBF data or failure rates, but it is worth an ask.
#33
Hope the second fix is the last fix. I'm a little concerned, mostly because we just got a Targa! Definitely hoping that yours is a fluke. That said, we've not had any issues with our 997 cab top, so the odds are that your problem is a one-off & that the first fix just didn't take. Glad you've got a good dealer, though. That makes all the difference in handling these issues.
#34
also posted in 'targa mechanism reliability'.... thank you for sharing, as i have same issue with headliner (one side more noticeable than the other). i'm still under CPO warranty and will take back to dealership where i purchased -- hoping repair is covered as this does not fall under normal wear and tear
#35
m5biemer (06-03-2023)
#36
Are these Targa roofs becoming more prone to creaks and issues down the road? Also, curious to know how expensive to fix the Targa roof when there are issues.
#37
#38
The dealership still has my car, and it will be warrantied for 2 years after this fix...so fingers crossed. Anyone else seeing these failures...I sort of feel special that I have had 3...
