KW HAS on 991.2 S
That’s how my rear looked too
I feel like mine dropped lower than what I've seen here...my fronts are maxed out, but my rears still have more to drop. Don't ask me what I did to have it sit lower, I had a couple of friends who are mechanics for a living install it for me while I worked.
The following 3 users liked this post by dj_dub:
Do you have PDCC? if not, that's why you are lower than others.
Quick update.
I tried a few different tires pressures and here are the best suited that I found.
These are for street only, I will not suggest track pressures because every track and daily temperatures require individual settings.
PZero: F 36 psi - R 46 psi
PS4S: F 38 psi - E 48 psi
The car isn’t bouncy anymore and there’s plenty of both, grip and feedback. Perfect oversteer to precisely position the car.
dj_dub (09-04-2020)
yeah you’re definitely lower. I used a picture of your car to show my mechanic the ride height I wanted lol but unfortunately that didn’t turn out.
Hey Wendell. Is it possible that yours is just installed without the zero-springs?
Gotcha, makes sense. Thanks for that information. ...Yes, definitely have some negative camber front and rear. Getting an alignment on Wednesday to correct it.
ZerOG (09-04-2020)
I thought so too, but I definitely still have them...I checked when I got the car back and when threw on my new wheels.
Damn man, sorry to hear that.
I'm confused, can someone clarify?
Does having PDCC allow the KW HAS to go lower or higher?
If I'm reading this thread correctly, dj_dub has PDCC and is lower than ZerOG who doesn't have PDCC who is riding higher.
But scottie46 has PDCC and his is just as high as ZerOG. ??? really confused because I don't have PDCC on my 991.2 and I was seriously contemplating the KW H.A.S. but not if it cant go as low as needed to achieve the look i desire.
Thanks.
Thanks.
