HELP! Dealer stunk up my 991.1 Cab
Hi gang-
As part of a cabin air filter replacement service, by dealer sprayed something in my HVAC system that is driving me nuts and is not going away. The best I can describe it if you get in a car that is driven by someone who wears a lot of cologne. Or the smell walking into a busy barber shop. As soon as those top front vents start blowing, BAM! If I run the A/C, eventually most of the stink goes away for that drive cycle. But it has been a month with little improvement.
I took it back to them and apparently they are not as "olfactorially sensitive" as I (I might have made up word there). They had me smell the freshener, and it DID have a scent.(Why the hell you would ever put something in a customers car that as a smell?"). But what they had me smell was not as bad. They didn't know what to do because any treatments might make it worse, they claim, and we agreed that it SHOULD go away over time.
I have STFF and have found threads about smells, but most of these relate to "musty" odors caused by moisture. This is not that.
Ideas?
Ideas?
Maybe an ionizer while letting the AC run for 20 or 30 minutes? Those usually get rid of any kind of smell.....
One of those shock treatments used to remove VOCs would almost certainly get rid of if, though you have to live with the after smell of that for about a week. My daughter has immune disorder and severe chemical sensitivity so we have to shock all our cars when new and it eliminates odors from everything. Smells like chlorine for about a week though.
The following 2 users liked this post by Penn4S:
AdamSanta85 (05-27-2020),
Class5Kayaker (05-29-2020)
I agree with the idea that it's probably somewhat in the filters, but the dealer swears that these new ones where not in place when they did their "treatment"
As for the ionizer/ozone treatments, I am going to look and see how much I can do this myself. Otherwise a good detail shop ought to be able to do it. I am actually thinking of opening up one of those jars of Ozium (stuff is fantastic), scooping some out, and making a little packet to reside where the outside cabin air filter goes, and seeing if that makes a difference after a couple of weeks.
My friend had his ducts at his home cleaned and they put some type of "air freshener" in the ducts. Drove them crazy but it passes with time. It would be nice to ask the owner first.
The following 6 users liked this post by 0luke1:
Chaos (05-29-2020),
Class5Kayaker (05-29-2020),
George from MD (05-28-2020),
HkPlinker (05-29-2020),
pfbz (05-29-2020),
and 1 others liked this post.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Remember this is in the HVAC system.
But if I do that and it works, I will still give you credit for the idea.
I'd take the cabin filter out into fresh air for a bit, then see what it smells like. If it stinks, you could put it out in sunshine for a day or two, and/or ozone treat it. Or just replace it.
See what the car smells like running the AC without it. If better after a while, replace it. If not, you will have to treat the air ducts.
If it is in the air ducting, put an ozone generator inside the closed car and run the AC/heater fan on high with air flow set to recirculate. That might take a few hours of ozone treatment. Just guessing. Trial and error...
The following 3 users liked this post by 0luke1:
