Passenger Side A/C blowing cool, but not cold
All My 991.1 has ice cold a/c on driver side but the passenger side is much warmer. I have the temps set the same on both sides and have run the temps up and down as well as used the SYNC mode.
Seem like a changeover valve. Any ideas before I call the dealer to get it looked at?
Thanks!
Thanks!
The following 2 users liked this post by VA951:
Pavegeno928 (05-13-2020),
Rich_Jenkins (05-14-2020)
Thanks. I called the dealer and they said it could be low on freon. I've had two recharges in the last three years. They said it wasn't a leak. CPO just expired in March. Hope it's not a condenser.
I not sure how a "sealed" system can be low on freon (twice in 3 years) and not have a tiny leak?
Anyone care to enlighten an ignoramus?
TIA
TIA
Thanks!
Thanks!
Pavegeno928 (05-14-2020)
Did you experience a hissing sound?
No. Very slow leak. It took a couple of months to be noticeable after 1st and 2nd visits to dealer. The valve is on the passengers side between front wheel and door. Apparently, as refrigerant leaks out things close down in a sequence. Passenger side cooling is one of the first things to go out.
Be an idea to get a recharge kit and DIY. I used to have to recharge my BMW E46 every 6-8 months with a can. Overall capacity was around 2 lb, a recharge kit was about a lb. Symptoms I would usually get were differential cooling, left vs. right. Plus an odd "gargling" sound which apparently was the air in the system cavitating under pressure.
Of course that's just a temporary measure, and that will not ensure the "correct" amount, or suck and refill, like they will do at a dealer. But at $20 it's worth considering if you are away from the dealer.
It's a pretty straightforward process.
Typical DIY here, but there are lots of them:
https://www.oreillyauto.com/how-to-recharge-ac
flgfish (05-14-2020)
That's funny that you said that because my 88 911 had the same issue just a few months back.
It only failed once on me and that was three hours from home in the Alabama summer. It was a nice drive home.
paddlefoot64 (05-14-2020)
No longer freon these days, the word is "R134a" ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
