Climate Control
Climate Control
I posted a similar question (well the exact same one) on the 987-981 forum but since I am also looking at lightly optioned base 991 cars I wanted to ask here as well. How would you guys feel about storing your car in a non-climate controlled self storage unit? In the midwest where I live, summers are 90+ degrees and humid, while winters are kinda mild when it comes to snow but below freezing temps are the norm.
Perfectly fine. I store mine here in NJ and our winters get cold. Just put it in a trickle charger, some additive in a full tank of gas, and you’re good.
Trayvon,
There are companys that make full zip up automotive bags for your car by size of vehicle Google it as I can't remember which ones maybe start with calcarcover.com but you drive onto it then zip up your car up your car in it. Why not? If you're having to store your car where car where mice and whatever else could eat it. I would use something like that if I had the funds and had to store my car. Below is 2012 my MT base currently getting factory PSE installed!
Eric
Eric
https://rvshare.com/blog/how-to-keep...ut-of-your-rv/
I'm in FL and my car is a DD, I do not store it in winter/summer. For that I would defer to the folks who store in the winter months.
Also, paging @LexVan
The car won't really be in "storage" in the traditional sense that it won't be driven, it will be driven at least once or twice a week. I don't know of mice or rodents are still a legitimate concern at a storage facility.
A car "bag" sounds like it might help, although it could also trap moisture, and I've heard car covers can damage paint?
I highly doubt I would have access to electricity. Most self-storage places are not going to want to let you plug in a fan that runs 24/7/365.
My garage (attached to house) isn't heated (or cooled) but it doesn't get below freezing. In the spring/summer/fall, the car gets driven plenty. I put it on a trickle charger if I am going to leave it sitting for more than a week and keep the tires well inflated and at least a half tank of gas if stored for much longer periods.
Set up the mouse hotels that they enter, eat the poison then leave an hopefully die elsewhere. Put some moth ***** under the car. Check on it every now and then and look for mouse droppings. You could probably foam or caulk gaps if you were planning on being in the unit for a while.
For 20+ years I've kept an RX7 in a rather ramshackle unheated garage. The car gets driven only a few times a month. I learned that rodents are very industrious and can do much damage in as little as a day or two. They chew through wiring insulation and store seeds in all the wrong places. They also bring in nesting material or shred parts of your car for use as nesting material. And their bodily wastes are the worst. They are more likely to be a problem as summer ends and the days grow shorter when they seek places to spend the winter. I've tried all manner of repellents - clothes dryer sheets, mothballs, etc. They don't work very well. For my situation, the best approach was to open the hood and set 2 or 3 spring traps (peanut butter bait) in the engine bay. (I object to untended box traps and glue traps at needlessly cruel. Use of poisons can result in dead mice killing other animals or rotting away inside your car.) The local rodent population will be quickly depleted and you probably won't catch any more until the next Fall. Still, I keep the hood open and baited traps in the engine bay between drives.
Yikes this sounds like a bigger deal to concern myself with than temperature. Is it possible the storage facility will be airtight enough to not allow rodents in? Seems like they'd need at least an inch or two and if you could guarantee there aren't any gaps you'd be fine. Or I could just get a car "bag", but I don't know what kind of damage that could do to the paint... And I don't want to pay $5k+ for a full Xpel
