Rear fender shark fin PPF
If you were to cut it out of a piece of square material, 18"x18" would suffice. I can sketch it on graph paper and send it to you if you'd like. Just happen to have a set in my garage.
That would be great. Thank you. Im looking to get then made in matte black PPF. I know there are magnetic versions but that will likely get crud under it and scratch up the ceramic coated PPF. Yes I want to protect the ceramic coated PPF on the fenders with more PPF.
I agree with that. I will likely go higher and wider. My PPF shop had a 991.1 in the shop and they just puled off the factory PPF and there where around the factory shark fin. I feel that it needs to be bigger.
