Turbo system : Finishing details , and corner balance at Supreme.
Took a partial day off to work on the project car today @ Supreme. Dropped it off for a corner balance and alignment.
Really appreciate the team, tools and the latest equipment they have to set the cars up right.
Results
Total weight 3156. ( No driver ). 50.68% cross weight with Driver ( 182 lbs ) in the car and 3/4 tank fuel. Alignment .01deg toe front, .17 toe rear. -1.5 camber front, 1.5 camber rear.
May add more front or rear camber the car feels like it has a high roll stiffness with the springs being run. Ride height is set to OE GT3RS.
Towed the car in, before staring it. With the new exhaust manifolds, Down-pipes, and center section, the inconel 625 will start to turn a straw / blue color after a few heat cycles.
Next:
Dyno calibration and performance measurements.
Mods: Turbos, exhaust manifolds, Inter coolers, Inlets, plenum, down-pipes, active center section. Looking forward to sharing more on the results.
other: B16s, GT3RS Brakes F/R, ALTI Wheels, MPSC2s, AEM CD5 Data logger, rear seat delete, custom water meth system.
Temperature and Pressure sensors. ( Driver side )
( Pass side )
Side shot with some wheel!
Results
Next:
( Pass side )
polobai (01-15-2020)
