Rennlist Grill Install Cost
Old 12-14-2019, 05:25 PM
G8tor
G8tor's Avatar
FWIW, I had the rennline grills installed on my car about two years ago by an Indy and the labor charge was $202.50 and they gave me a 20% discount for being a PCA member.
Including parts and shipping the total was $456.25.
Old 12-14-2019, 08:40 PM
justabout
justabout's Avatar
Originally Posted by 991carreradriver
I installed the Rennline Grills on my 2016 911. The actual grill install after the cover was removed took about 20 minutes. The removal of the bumper cover with just me was about 45min and about 30 minutes to put back together. It is not a big deal. The biggest PIA's are the removal of the side lights. My 2016 had very little extra wire to reach & disconnect the connector. The other was removing the retaining clip on each side. I suggest that if you attack this project be sure you have something that looks like a screwdriver with an angular hook at the end. I used a set of rug weaving tools purchased on Amazon for abut $10. You will need this to remove the retain clip and reinstall it.
I fabricated a hook out of a metal coat hanger. Worked well.
Old 12-14-2019, 09:50 PM
Jack F
Jack F's Avatar
https://www.harborfreight.com/pick-a...yABEgKCqvD_BwE
im not sure which i used but it was one of the small hooked ones. Second from the left I believe. Everyone should have a set of hook and pick tools. Super helpful.
Texas Porsche (12-14-2019)
Old 12-15-2019, 10:26 AM
991carreradriver
991carreradriver's Avatar
^^^^ This is the set I purchased. I can't tell you how many varied uses I have found for them since I purchased them. Every toolbox should have a set.
Old 12-15-2019, 11:25 AM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,184 Likes on 711 Posts
Yep, very useful tools. I use this to remove the rubber ring gasket on the oil filter housing when changing the oil.
Old 12-15-2019, 12:31 PM
sampelligrino
sampelligrino's Avatar
Originally Posted by TRM
I’ve also seen the Zunes on a GTS at a recent event. If you’re really **** about appearance you may be disappointed. But I still think they are a better option.
FWIW this is my experience as well. I felt like the Rennline grills were more OEM looking & went that route. OP I had a reputable shop install my Rennline grills and they charged me 400 for the labor
Actually if I remember correctly I don't even think Zunsport had the grills I needed for the third/center radiator after contacting them, so I didn't have a choice
Different strokes for different folks, but in any case getting some form of them installed is fixing a big oversight from Porsche. Way less crap building up and smacking against the radiators
Old 12-15-2019, 10:09 PM
phefner
phefner's Avatar
Agree. Rennline has a nice OEM looking solution.
Pictures of my recent 3rd Radiator install with screens. No exposed hardware or straps to hold screens in place.
Quick Reply: Rennlist Grill Install Cost
