PDK shifter vanity plate construction
Does anyone have a photo they can post of the underside of the PDK (for a 991.2) vanity surround assembly showing how that movable vanity plate is fit into the surround assembly? Is it easily removed?
Looking into potential refinishing options. May buy a spare to mess with if that plate can be removed for refinishing to remove the glare from the silver surface.
How about replacing it with a shift boot? Check out the thread and you can at least see how to remove it: https://rennlist.com/forums/991/1169...-question.html
Be sure to check out the other thread that is referenced within it.
Also, found the part in the "PET". It was under "levers and pedal cluster" not "Center Console".
