991.2 Front track increase
I am lowering my .2 GTS and at the same time I am considering to lengthen the front track. It has CL's so I can't jut add spacers to the wheels. So I was looking at Elephant Racings adjustable lower arms which would allow the front track to be lengthened. However I don't know how much thread length is available on the steering tie rods. Anyway looked at this already? Thanks
I've looked into the Elephant setup front and rear. Basically a every mans RSR setup.
Before I went that deep on my GT3 I've installed 9.5's +45 offset and am pleasantly surprised on the increased grip and turn in. I figured this is a beta test. It doesn't increase the actual width but a great preview. If you do go with the new setup it brings the stock centerlocks all the way out to the edge of the fenders. Depending on tire selection you may not like how aggressive it is.
I went to .2 GT3 offsets on my GTS with a set of HRE LW's. The nice part about adjustable LCA's is you can get more camber and increase the track. They also have caster adjustment so it can be corrected for lower cars or track increase. I am lowering my car from GTS SPASM ride height to GT3 ride height.
