PCM 3.1 ribbon cable connectors
#31
I never did find a replacement for the tan plastic clip. I broke off one end on mine as well, and just put it back in. The one side was enough to hold it in place believe it or not. I'd try that and see if it stays with just one side. Since this thread everything has been working as expected.
#32
nothing panned out I ordered. The bulk ones https://www.amazon.com/dp/B07VJXNTY7...roduct_details are tiny and the daisy chain boards are top flip not snap type. I think this part is going to be impossible to find. On a PCB repair forum they suggested hot melt glue.
I’ll be doing that and at least if it needs to be removed hot glue isn't permanent
#33
received yet another order of these plastic clips this time from the UK. A company called http://tme.com. https://www.tme.com/us/en-us/katalog/connectors_46/
No luck. I've spent about $50 acquiring these sockets and cables without any luck, my advice, don't break it ;-). Sadly you don't know the amount of force needed until you do one. Also remember the plastic should NEVER remove completely, the little tab should catch it, these move very little, you may think its not open but it could be and you're one step away from breaking the plastic.
#34
#35
It can be removed reasonably easily from most surfaces. Depends on the grade.
#37
#39
The ebay description is as follows;
FPC/FFC Connector 0.5mm Pitch Top / Bottom Interface 4/6/8/10/12/14- 50Pin Lead
Link;https://www.ebay.com/itm/234893290122?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=iosnuvouqoy&sssrc=2047675&ssuid=TOr9CKaTSna&widget_ver=artemis&m edia=COPY
#40
I have the same problem with broken FFC FPC top connector but may have finally found equivalent replacement on ebay. I just ordered 5 of the 30 pin and 5 of the 50 pin ones today.
I have to dig it up again.
#41
I contacted and ended up having Rossmann Repair Group in Austin, TX repair it.
Louis Rossman has a YouTube channel and they do almost exclusively repairs on Apple products, mostly Macbooks.
The FPC Connectors are used in a bunch of those so I thought it was a worth a shot.
I had to provide the connector.
The cost with shipping (r/t) and the repair was ~$250.
I ordered a bunch of different ones and ended up shipping 3 different ones to them.
This is the one they used.
Mouser - Amphenol Aorora F314-1A7H1-11030
slowrey (10-07-2023)
#42
#43
i had same issue with PCM 3.1 and tried the ribbon cables someone listed from Amazon but they didn't work. I contacted Roman at https://acsbyroman.com/mr12volt/ and he sent me the ones that are included with the Mr12volt kit. They are a little shorter than the stock ones that go between the screen and board but they did reach and worked. I tried reaching him this week for a freind who wanted to buy a kit but he's on vacation so you might need to wait until next week.
#44
Basic Sponsor
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
COUPON CODE "toys" FOR FREE INSTALL KIT!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
911jan (04-10-2024)
911jan (04-10-2024)
