Garage Heating
Old Oct 29, 2019 | 07:56 AM
Gary JR's Avatar
Gary JR
PELONIS 5,200-BTU Oil-Filled Radiant Cabinet Electric Space Heater with Thermostat
Fridge in the garage also. The idea is to keep above freezing.
Old Oct 29, 2019 | 07:57 AM
ADC1's Avatar
ADC1
Originally Posted by k_h_d
I am looking for ideas on what the best way to heat our garage. I am connecting the house to a 3 car garage. Construction is underway. I will be insulating the remaining 2 walls and ceiling, eventually putting new efficient garage doors. What have others done to heat their garages? I know you can get electric heaters. What about running ductwork into the garage for heating from the house furnace?
I don't think it is that easy to just add duct work. Your HVAC system should be sized for your house including the ductwork. You should call a professional.
Old Oct 29, 2019 | 09:14 AM
6MT's Avatar
6MT
I had a forced air natural gas ceiling mounted heater in my previous garage and just built a new home and have a natural gas radiant tube heater in both the attached garage and my stand alone garage. I would personally not go back to a forced air heater. Although it worked quite well it was noisy and with moving air it seemed to blow dust around quite a bit. The radiant heater is nearly silent and instead of heating the air as much it seems to really heat the objects and floor quite well, so when I open the over head door to take my snowplow out it seems to get back up to temperature much quicker. It is a very nice dry heat as well.
I would also consider a mini split in my next build. They are also really quiet and having the option for air conditioning would be very nice in the summer.
Old Oct 29, 2019 | 11:38 AM
ClassJ's Avatar
ClassJ
It is also illegal to have common ducts between the house and garage due to the potential for fumes to find their way back into the house.
If you have hot water heat in the house you can set up a zone in the garage but for a fast recovery situation like a garage, you need a different type of system.
Old Oct 29, 2019 | 11:46 AM
thesaintusa's Avatar
thesaintusa
Currently have forced air. HATE it.
Floor temp is much colder compared to the temperature at the level of the thermostat.
Every time you open the garage door in the winter the heater kicks in.
Previously had radiant heat, with ceiling fans. Loved it.
Upfront infrastructure costs much higher.
Operating costs very cheap.
Very even temp in the garage. Floor temp is what the whole garage feels like.
Floor is warm (important if you work on your car). I guess you could relocate the thermostat for the forced air to the level of the floor.
Opening the garage door had less an effect than when having forced air as the garage slab is a HUGE heat sink.
When the garage floor gets wet it dries quicker.
If I was starting from scratch I would definitely go with in-floor radiant heat.
Old Oct 29, 2019 | 12:24 PM
911sccab's Avatar
911sccab
My favorite is the radiant floors in our attached garage. Gentle, quiet heat. But slow to change temperature. And hard to add if your floors are already poured.
My second favorite is the tube heaters in the ceiling of our barn. The heat coming down in February reminds me of sitting on the beach! Ours warms the barn from 45 to 65 before I finish my coffee.. but you need height to accommodate these.
The Mitsubishi wall units look neat too.
Old Oct 29, 2019 | 12:38 PM
Dan Nagy's Avatar
Dan Nagy
I have two propane gas heaters in the garage area (garage plus a garage utility room). They are hooked up to a buried propane tank that also runs a Generac and gas stove. If you are doing construction now, it might be worth considering running the pipes if you want to run more than just garage heating.
Old Oct 29, 2019 | 02:19 PM
luv2race's Avatar
luv2race
I'm in the northeast so we have extreme temperatures. I used a Mitsubishi split system like Mooty because I needed both heat and cool. My oversized 4 car garage with 15' ceilings required two systems but operating cost was not noticeable on by energy bill. My prior house had a 2.5 car garage with a finished upper level but open to the garage level and one system managed the temp fine.
Old Oct 29, 2019 | 02:41 PM
worf928's Avatar
worf928
Originally Posted by Jay-S
There is a cheaper, less extreme alternative to in-floor radiant heating: one or more infrared panels.
Amazon Infrared Panel
We have one in our master bathroom on our ceiling, which has concrete floors and a big floor-to-ceiling window. In the winter we struggled to get the temp above 64 degrees. Now it is toasty.
That would cost me - at my electric rates - ~at least $130 per month to operate during winter as it would be on all of the time. While it may keep one room toasty, one panel will not keep my 2000 sq ft garage at working temps (>55F) when it is below freezing during the day and sub-zero outside at night. One panel might keep one corner of the garage at working temperature. Based upon a 'one-room' 'one-panel' metric I'd need no less than 8 of the panels.
My natgas-boiler-fired in-ground radiant system will keep the garage at working temp all winter and costs less $200 per month to operate (or about $250/mo if you include a generous allowance for yearly maintenance costs.)
It is infrared so the heat is different. It heats objects not the air but it is very effective. It is also very safe - no hot spots or anything - and it stays on all winter in our house.
In-ground radiant is different too. It heats the floor. In the depths of winter the floor is at about 70-75F so it is very comfortable to work on whether you are standing or lying. Also, there is - effectively - no temperature change when a car leaves or enters the garage. While the temp drops while a garage door is open, within a minute or two the air temp is back to 'normal.'
Old Oct 29, 2019 | 02:54 PM
thesaintusa
In floor radiant heat worked perfectly fine for me living in frosty Canada where the temps would get to -30C for EXTENDED periods. The slab was over engineered, and poured on piles with a insulation barrier around the foundation and under it. As mentioned the temps would get back to being warm quite quickly with the boiler rarely kicking in. Benefit of a heat sink weighing thousands of pounds.
Old Oct 29, 2019 | 03:10 PM
worf928's Avatar
worf928
Yup. Exactly what I did. Insulated frost-wall sides, insulation on the ground, radiant tubing on the insulation and 6 inches of steel-reinforced concrete poured over.
Old Oct 29, 2019 | 03:32 PM
hbear's Avatar
hbear
Our garage simply has it’s own furnace in it (same as what we use in the house except with a lower output).
works great, simple to install, inexpensive to run.
Old Oct 29, 2019 | 06:10 PM
Jay-S's Avatar
Jay-S
In-ground radiant is ideal. Retrofitting it can be problematic though.
And FWIW my wife pays the electric bill She says she doesn't see that much uptick from the panel being on but we're also not talking about a garage or an extreme temperature variation.
Old Oct 29, 2019 | 06:19 PM
amfp's Avatar
amfp
I did a radiant floor as well using existing boiler and set up an additional zone. Before installation, I had all the insides of walls (between studs) sprayed with insulated foam. So it is well insulated with well-insulated garage doors.
Still, needed air conditioning, I added two Fujitsu split air-cond and heat units.
Old Oct 29, 2019 | 06:36 PM
Homeles's Avatar
Homeles
When I lived in NC, I went with radiant heat. The system was encased in a rubber mad. Laid on the floor and covered with marble tile. Worked great.
