Please Help - Squeaky Brakes
Old Oct 27, 2019 | 04:46 PM
  #31
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Originally Posted by rubenhak
At which point would you replace the rotors? This is 2013 C2S Cab. 37k miles.
If they are not damaged they will last a LONG time so don't worry!
Old Oct 27, 2019 | 04:53 PM
  #32
rubenhak's Avatar
rubenhak
are you referring to tiny little cracks around the drilled holes?
Old Oct 27, 2019 | 06:02 PM
  #33
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Are you referring to what appear to be tiny little cracks on the entire surface of the rotor? Here is what I mean by damage (chips):
File Type: pdf
Old Oct 27, 2019 | 06:13 PM
  #34
Larson E. Rapp's Avatar
Larson E. Rapp
Originally Posted by box
This car could catch a Boxster and run right up over the top of it--brakes squealed the same way (randomly) as my 911:
What the heck is that, a turbocharged PT Cruiser?
Old Oct 27, 2019 | 06:48 PM
  #35
DY369's Avatar
DY369
It certainly is frustrating and random. Had one 991 and it did it (and was told it is normal) and had another 991 (my current) and it does not do it. I certainly prefer the one that does not do it. Is my current 991 abnormal because it does not do it?
Old Oct 28, 2019 | 01:48 AM
  #36
BSO's Avatar
BSO
Mine have never squealed in the 8k miles since new. I did several high speed stops early on.
Also, when I wash the car, I use my garden hose with a nozzle set at the point where the water comes out at the highest pressure and thoroughly rinse all four rotors and pads until no more dust washes off.
No noise issues whatsoever. I do agree that using the assembly grease on the brakes when replacing pads/rotors will help.
Old Oct 28, 2019 | 10:19 AM
  #37
box's Avatar
box
Chladni Plate. Fun, ironic fact, he was a German physicist.
Old Oct 28, 2019 | 10:36 AM
  #38
rockrdude's Avatar
rockrdude
Mine do it, sporadically. Most cars with big brakes and rotors do. No big deal. It's very common for cars that are designed to go fast and end up driving 95% of their lives at city speeds.
Old Oct 28, 2019 | 10:41 AM
  #39
AdamSanta85's Avatar
AdamSanta85
My .1 S squeals like a pig when brakes are cold. Meh, because race car.
Old Oct 28, 2019 | 12:59 PM
  #40
Pmorritt's Avatar
Pmorritt
Having owned many motorcycles including the current ones, some have had the dreaded brake noise. I removed the pads from the offending caliper, apply a very small amount of Copper Paste to the back side ( caliper piston side) of the pads and reassemble. Brake squeaking gone. Dont know if this will work on our cars but I’d give it a try.
Old Oct 28, 2019 | 02:06 PM
  #41
SeeForce's Avatar
SeeForce
fast cars have squeaky brakes or somesuch.
Old Oct 28, 2019 | 02:10 PM
  #42
box's Avatar
box
Best explanation yet!
Old Oct 29, 2019 | 11:04 AM
  #43
Bud Taylor's Avatar
Bud Taylor
Default .1 and never a peep
I would first try turning rotors and then add new factory pads. Then new rotors if that did not work. I avoid puddles or spraying water on rotors when hot. I can not take squeal so i would have to figure this out as well. Factory pads make more dust but less stuff in them to cause noise. Might also try also replacing clips.
Old Oct 29, 2019 | 02:53 PM
  #44
box's Avatar
box
Presumably 'new'...worth a try. Brembo B-Quiet. 0.00795 PMU, can't beat the price.
Old Oct 29, 2019 | 06:26 PM
  #45
Carlo_Carrera's Avatar
Carlo_Carrera
Porsche says not to use this stuff but one thin line across the back of the pads will stop all noise.
