Problem installing RS skirts on .2 GTS
I just received and started installing the RS side skirts on my .2 GTS and really hoping someone can help me out. So I was able to get them on but the last 3 clips simply won’t clip in leaving quite a large gap. I’m aware that there may be a
3-4mm gap as reported by others but mine is much more than that. I feel if I can get the clip to lock in the skirts will sit flush enough. Can anyone help me out with this please. I attached a couple pics for you to see the gap.
Did you attach all clips to the car and the problem you are having is that you can't line up the last 3 clips with your side rail for install?
I've done 2 installs now on my TTS but they line up and fit is great.
Did you try starting to install from the opposite end to see if it is easier to end toward the front?
Just finished mine yesterday. Had them painted gloss black to match my wheels. Going for new PPF Friday.
We must have received the RS skirts at the same time because I am trying to install mine and have exactly the same issue.. The problem is that the last 3 pins have no support underneath it - unlike the other pins which have a spline running underneath it - so it is impossible to push the pins hard enough to click in. I also think that the rear edge of the skirt, towards the rear wheel, is a tad too high, which helps to prevent the pins to click in. I spent quite a bit of time yesterday trying to install - and broke a lot of pins in the process. I have some ideas and will post if successful.
SOLVED!
eysa - I solved it and was able to get the skirt on in about 10 seconds. I will post pics when I do the other side, but was so excited I got skirt on I wanted to post and save you a trip to the shop.
You have to reverse engineer it. Instead of trying to think of a way to push pins in with little to no support, take off the pins from the skirt and put the last 3 in the rail holes. Then push the skirt into the pin slots. Start from the back. Once you get the rear skirt in, the rest is easy.
I already tried using a paint mix stick in the skirt under the pins for pushing support - that did not work.
Was also thinking of drilling a hole in the bottom of the skirt and then using a screwdriver to push the pins in - then cover up the holes with caulk (it would be on the bottom, so no one would see it anyway). Luckily, putting the pins in the rail and then sliding the skirt into the pin slots worked.
Let me know if you have any issues.
MJG911 (09-19-2019)
I gave it a try and while pulling the rear of the skirt to get the pins out the entire skirt slid out from all the pins. I put in the last three pins and now just need to slide the skirt in to all the pins which is a bit difficult to do without an extra pair of hands. I will do it later when my sons is home to help. I can't see it not working. I can tell you that even though it wasn't completely installed it looked so much better then the side with the factory skirt. Can't wait to get them both in properly. Thanks for the help and for saving me the headache of trying to figure it out.
Yeah, this simple mod is turning out to be a pita, but I think worth it in the end. Frustrating as I have taken the skirt on and off about 5 times and broken about 7 pins. Also note that the rear screws do not line up, at least on my car as I have a 2015.1 GTS. Not a big deal, just an fyi.
I don't have pics of my install yet, but check out this link:
https://rennlist.com/forums/991/1159...on-my-gts.html
