Start/stop operation deactivated
https://t-design9.com/memory_module.html
and if you have a targa they make a smart module to allow you to open/close the targa top from your key fob.
That one is here:
http://www.mods4cars.com/blog/smartt...che-911-targa/
That one is here:
Dealer is blaming it on my aftermarket battery. They're quoting $764 to replace the battery and program a new OEM one. Seems a bit silly to me.
I do have a POR V2.0 scan tool with the battery programming function available to me. I suppose my best approach at this point is to try and successfully program the aftermarket battery.
Koala: Did it not dawn on you to tell us that you replaced your OEM battery with an aftermarket one? That little tid bit slipped your mind..
Your dealer is correct, it is your battery 100%. If you had a stock one then this wouldn't be happening. Now, the price the dealer is asking is truly absurd, so thats not an option.
I'm thinking about getting a Lithium Ion battery. If I do, I would have no problem selling you my OEM battery about a year old, but your answer lies in the battery and its voltage.
The auto start/stop works off of a specific voltage connected to the battery. Its not the same as the voltage that starts the car, or powers the accessories, its specific to every car and thats how it determines when you are moving or standing still, thus starting or stopping the engine. Your AM battery may work just fine for all other auto requirements, but the auto SS will usually be the problem because of that micro voltage which is specific to your car.
If you send an email to the Vlad at T9 designs, I bet he will know the solution to your problem and the answer to the error message.
If you do get a response please do post it here so we all can learn.
NOTE: I just sent him an email with the link to this thread so lets see if he can shine some light on the problem.
I replaced my OEM battery with a non OEM with no issue. It's for my Boxster but same engine as a Base 991.1. Since you replaced your battery, I would check the connections. Pull them off and re-land them and make sure the connections are tight.
Duracell Ultra Platinum AGM Battery for 2014 Porsche Boxster H6 3.4L 650CCA Car and Truck
PS - Porsche of New Orleans wanted to charge me $980 for a battery.
Here is his response:
As other user said - this warning pop up when the conditions aren't ideal for start/stop. Most probable culprit is the battery. It would be interesting to see the voltages at the time of engine start, and at the time of message. And also to know was the A/C running and how hard?
Based on his response, it seems to be an issue with the draw seen by the auto start/stop which is why I suppose he is asking about the AC because it pulls a lot of current from the battery..
Car is on a battery tender every night as well. I can hookup my POR V2.0 scan tool and pull voltages from that in addition to the readout from the dash - but I'd trust the scan tool more on that one.
I'll check my battery cables and go from there. Will report back for sure as it'd be great to have a "solution" for anyone else that searches this issue in the future. I'll be sure to edit my original post if I land on the actual cause of the issue.
I do have a POR II scan tool with the battery programming function available to me. I suppose my best approach at this point is to try and successfully program the aftermarket battery.
Battery in question: https://www.costco.ca/Energizer-H8-A...100486791.html
At least Costco will take virtually anything back. Worst-case, I'll try a different battery. It's just hard to find alternatives to OEM here in Canada. We truly have very little selection.
If it were me, I would program the new battery and see if it fixes it.
I had the iCarsoft POR V2.0 tool with the BMS functionality but I couldn't get it to write the new battery info. Took it to my Indy mechanic and had him do it with the official tool.
POR II does not have BMS functionality.
Here's my post from the battery thread:
Another member used a diff tool:
I inputted this for the interstate agm battery in PIWIS II without any issues.
Battery Capacity: 95
Technology: AGM
Scanner code (15 characters including the space): Serial number for the porsche battery. It seems like it's 3 numbers, space, followed by 11 more characters. I highly doubt it matters what you put here. Maybe try making it "XXX XXXXXXXXXXX" if you don't have the porsche serial.
Party number: 99961109510
Technology: AGM
For those who are looking to DIY their battery change registration, I did mine recently with an Autel MD808P scan tool. The Gateway control unit has data fields for
- battery capacity in Ah
- battery type (flooded, AGM, Li-Ion, etc)
- Porsche part no.
- Porsche serial no.
- Porsche part no.
