Brake Replacements - Multiple Questions
#31
I was told by a tech that the holes on the outer edge of the rotors are actually a good way to estimate rotor life remaining. It isn't actually a through hole but a cavity/divot that is drilled to a certain depth that when it is no longer discernable (because the rotor surface has worn away) the rotor is fully used up.
