Installed GT3RS side skirts on my GTS
Old 09-02-2023, 12:05 PM
  #286
mdcm17
mdcm17's Avatar
Originally Posted by KP993
When I first saw your pics I am like, I can't remember I took those shots on my GTS before. Here is your identical twins: no sunroof, 7-speed manual, clear side marker, side decals, centerlock, red calipers, red seat belts.................
Great taste if I do say so myself... And Canadian twins, too!
Next (and probably final) planned mods are Sport Cats and/or Headers and maybe lowering springs. I like the mild drop you did with the VTF as the roads in Toronto are terrible and I don't wanna go too low. Cheers my friend!
Old 01-02-2024, 02:17 AM
  #287
Revsportz
Revsportz's Avatar
Originally Posted by slocumda@yahoo.com
For those who can not deal with the gap between the side skirt and body these pictures show a solution you might want to consider. I'm of the opinion that any heating of or manipulation of the skirt to conform more closely to the body of the car is not going to work. So my next thought is to fill the gap which I did using Midnight Black ColorFast Tile & Grout Caulk. This was relatively easy and did a good job of making the gap disappear. The caulk matches the skirt quite closely in both color and sheen. Obviously, if you want to take the skirt off in the future you'll have some difficulty but clean up and replacement should not be a big deal. Hope this helps, Doug
Did you ever take out the side skirts after the grout? How easy was the clean up and was there any damage to the paint. Thanks
Old 01-02-2024, 05:21 AM
  #288
slocumda@yahoo.com
slocumda@yahoo.com's Avatar
Have not removed the skirts but I have PPF and ceramic coating which should make clean up a little easier. Keep in mind the area that is of concern is very small and will be covered up by the OEM side skirt anyway, no worries really. Hope that helps.
Old 01-04-2024, 09:37 PM
  #289
Revsportz
Revsportz's Avatar
thanks.. that’s a good idea to put PPF on sides, I have a narrow body carrera T so no factory sides.
Old 03-29-2024, 09:35 AM
  #290
Johgts
4th Gear
Johgts's Avatar
Yes car is lowered by about half an inch with H&R VTF.
991-504-595-86-OK1
991-504-596-86-OK1
I like the matt black color better as it gives more contrast to the car, and if I scrape them badly they can be easily replaced without painting.
Yes plug and play, no modification is required.
Don't have before and after in same angle, but any other .2 GTS photo will give you an idea. It hit my ankle couple times at the beginning but afterward I am well aware of it so no issue at all.
Mine is the more aggressive .2 GT3RS version.
is h&r vtf plug n’ play in Gts with CL wheels?
Kw say kw h.a.s won’t fit on GTS with CL wheels.
Old 04-05-2024, 02:02 AM
  #291
KP993
KP993's Avatar
Yes H&R VTF fits my GTS with CL wheels with no issues. When I did my research few years ago I concluded that KW HAS won't fit. I can't tell now as they may have developed a new HAS product which might fit.
Old 05-21-2024, 07:03 PM
  #292
9krpms
9krpms's Avatar
Can anyone confirm that the 991.1 GT3RS skirts will fit a widebody 991.2 without major issues?
Didn't see anyone on here that tried it - but assume they fit the same. I prefer the more subtle look of the .1RS skirts.
Old 05-23-2024, 10:40 PM
  #293
Catharpin
Catharpin's Avatar
Originally Posted by hmansdorf
Are the Skirts the GT3RS or the RS Flared Skirts?
This is my question.
I am interested in the "RS" Flared Side Skirt Kit
https://www.suncoastparts.com/product/PK991TSKIRTS.html
Are these the same parts as discussed here earlier?
Old 05-25-2024, 07:31 PM
  #294
Fascin
Fascin's Avatar
I was just reading about 250$ for the sideskirts. Where can I order them? I‘m from Germany and couldn‘t find any shop that cheap.
thank you!
Old 07-28-2024, 11:30 PM
  #295
c615586
c615586's Avatar
Originally Posted by Hokidachi
I did not want to use caulk to plug the gap so I designed a plate and after a number of prototypes ended up with this. It's not perfect but the gap is plugged : )
Can you share your STL file? Totally understand if you want to keep it proprietary.
Old 07-29-2024, 12:41 AM
  #296
Hokidachi
Hokidachi's Avatar
It’s been a little while, I just need to find it!
Old 07-29-2024, 12:48 AM
  #297
Hokidachi
Hokidachi's Avatar
Here are the F3D files (I don’t have the STL files).
File Type: zip
Old 07-29-2024, 09:43 AM
  #298
Ahmad310
Ahmad310's Avatar
@c615586 do you have S or 4S?
Old 07-29-2024, 10:33 AM
  #299
c615586
c615586's Avatar
4S.
Old 07-29-2024, 09:26 PM
  #300
c615586
c615586's Avatar
Awesome! Thanks!!
Quick Reply: Installed GT3RS side skirts on my GTS
