Replace non multi function steering wheel
Old 08-31-2019 | 07:24 PM
Lotusnfg's Avatar
Lotusnfg
Default Replace non multi function steering wheel
Hi all,
2014 C2S with sport chrono, PDK, and non multi function steering wheel.
Is it possible to install a multi function steering wheel?
I have read many post where users replaced a multi function wheel with a sport wheel, but not what I would like to do.
Jeff
Old 08-31-2019 | 09:18 PM
Zeus993's Avatar
Zeus993
Yes, it can be done, at least in a 991.2. I recently went the OPPOSITE direction and removed the multi-function buttons, installed blanks, and a new 4-stalk clockspring.
You'll need to purchase the multi-function buttons from Suncoast, and I believe a wiring harness to get it work.
I have considered selling my multi-function setup but I may want to return it back to stock if I sell it.
Old 08-31-2019 | 10:01 PM
ZerOG's Avatar
ZerOG
I just happen to have an extra set of MF buttons and trims available.
Old 09-01-2019 | 04:03 AM
rezok's Avatar
rezok
I have one of these for sale with the column stalk, airbag carry's over PM if you like
Old 09-01-2019 | 11:47 AM
Lotusnfg's Avatar
Lotusnfg
Default Plug and Play?
So do these just plug into a non MF wheel?
So do these just plug into a non MF Wheel?
If so what are you asking for them?
Jeff
Old 09-01-2019 | 04:16 PM
ZerOG's Avatar
ZerOG
Jeff
Do you have a picture of your wheel?
Old 09-03-2019 | 11:31 AM
Lotusnfg's Avatar
Lotusnfg
Default Different direction.
Hi all,
Thanks for the responses, very helpful.
Decided that what I really was looking for was a simple sport wheel with the paddle shifters.
After thinking about the use of the multifunction stalk, and my present shift buttons, I realized that it was the buttons I really didn't care for.
Regards
Old 09-03-2019 | 01:04 PM
MOWE's Avatar
MOWE
What’s the cost ? What else has to be done to integrate and ensure it all works?
Old 09-03-2019 | 08:59 PM
spraguedawley's Avatar
spraguedawley
It is not a problem as long as you change the stalk and control unit. I have a carbon fiber and leather mutlifunction wheel from my 2015 991TS that will work. I also have the Stalk and all necessary parts for it to function properly. Dealer can install for about $300. Let me know if you are interested.
Old 09-03-2019 | 09:06 PM
MOWE's Avatar
MOWE
Whats the cost of parts ? I have a 991.2 GTs with Sport wheel
Old 09-03-2019 | 09:22 PM
spraguedawley
This is from a 991.1 Turbo so it has the button shifters. For anyone interested in it I will let it go pretty cheap, like $700 for everthing. Its just sitting in a box.
I recently replaced my 991.1 GTS wheel with the 991.2 GTS wheel and it is a huge improvement. My GTS is a manual BTW.
Old 09-02-2020 | 12:24 PM
eilig's Avatar
eilig
I am looking to convert the non-multi function steering wheel in my 991.2 2019 Carrera to a multi-function steering wheel. Does anyone have the parts and are you willing to sell? Thanks!
Old 08-02-2023 | 11:47 AM
BoxCan's Avatar
BoxCan
Hi Guys,
I am so glad I found this thread. I have been contemplating for weeks about swapping my 991.1 MF, non-heated, non sport (thumb buttons) wheel for a 991.2 wheel. I got the airbag and the wheel on ebay already. The wheel is a 2020 Macan wheel, paddles, same MF buttons, no sports chrono thumb dial, has a heat button but I don't really care about adding the heat function.
Can I just swab the old wheel for the new one? Do I really need the GPS adapter? I have read the whole thread and getting a bit confused about the function of the GPS x-adapter. Some said it is for the 991.2 wheel to talk to the 991.1 car so the MF buttons will work. Some said it is for the sports chrono thumb dial buttons to work, but my new wheel does not have the sport chrono thumb dial. I am used to the center console sports plus buttons anyway.
So to summarize, if I don't care to add the heat function and no sports chrono thumb dial, do I still need the GPS x adapter?
Thanks in advance for all your input.
Old 08-02-2023 | 12:06 PM
dak911's Avatar
dak911
I also would like to convert my NON function wheel to be able to use the voice control for GPS and "Radio" functions is this possible 2019 Base 991.2 Cab PDK
Old 08-02-2023 | 12:21 PM
rensoyka's Avatar
rensoyka
2017 C2 PDK SC. I have the GT sport wheel with no stinking buttons period, just 4 stalks and 2 paddles, love it to death. I have voice recognition but I don't use it, it is activated by a very small button on the end of the turn signal stalk. check to see if you have it too.
Quick Reply: Replace non multi function steering wheel
