991.2 Carrera Hidden Launch Control (Non-Sport Chrono)
For those who are curious, it does exist and it works very well.
Follow these steps to activate and use:
1.) Make sure car is at operating temp
2.) Sport mode is a must (traction control off and sport suspension are optional)
3.) Depress brake pedal completely and hold
4.) With brake pedal held down, floor the accelerator. If done correctly, revs will build and hold at around 5000rpm
5.) Let the boost build a bit; let off brake pedal to proceed with motion (or let off the accelerator to abort)
Unsure about how this affects the PDK, but I'd assume all the logic that surrounds SC launch control applies with this. Don't go crazy and back to back with it. Use it responsibly.
Video below demonstrating activation and launch.
-Aatish
-Aatish
The following 3 users liked this post by Aatish:
This is similar to a 991.2 7M feature that was pointed out to me at my ATL delivery by the techs..
At stop with the clutch in, the engine will hold revs (I believe he said 4k RPMs), them conceivably you would dump the clutch.
He also said don't do it, not advised.
I think I'll follow their advice.
Aatish (08-26-2019)
exduluthian (08-26-2019)
In all the years of testing 911s, there's only one with a MT that I have dropped the clutch in: the 997.1 GT2 (and then only because Weissach engineered a very interesting LC system to build boost and made a point about it). And...it was fun.
Aatish (08-26-2019)
Aatish (08-26-2019)
Aatish (08-26-2019)
A full,wheel-spinning clutch drop is very hard on the clutch, especially in a 911 with so much weight on its driving wheels. The 4000-4200 rpm limit was new with the 991.2. On earlier cars you could perform a clutch drop over 6000 rpm. Use the right rpm for the traction conditions and the spinning wheels get the car going and when the tires hook up, the engine should be in the meat of the torque curve and off you go.
