Door pocket in my 911 has gone 'limp'
Hi guys, I have a 'New' 2012 Porsche 911 S, Convertible. Love it.
All of a sudden, the drivers side door pocket went 'limp'. I'm talking about the little side pocket in the door that has a little latch you fold open and then you put stuff like hand lotion or whatever in there. When I push it shut, it just opens right back up within about 10 seconds.
A friend looked into this and concluded that the only fix for this is to replace the entire large part called Door Pocket and it involves a ton of labor to do that. Or, maybe the part is not actually broken but is 'dislodged' and needs to be reset which also seems to involved quite a bit of specialized labor. Sounds like easily over $1k to fix. Yikes.
Has anyone else experienced this? Any suggested fixes or workarounds? I'm tempted to velcro but first attempt failed because there's not a lot of flat surface area on both sides... Picture below. I also made a video showing the behavior, at https://www.youtube.com/watch?v=Dq06...ature=youtu.be
Bart,
It sounds like there’s a lot more going on here than just a door pocket issue! Within your first paragraph you have described your drivers door pocket as “ went limp” and used for “ hand lotion” and popped back up in ten seconds! Are you sure this isn’t something for one of those little blue pills Sir? You should take it to the dealership then to the doctors to address either or both issue! They are both worthy of professional assistance as limp in anything is not something men want to experience whether in be in car door pockets or going to “pound city” 😜.
Have you taken it to the dealership to get a price? It could be $1000 dollars because it’s a Porsche. Or it could be less. I don’t see a why out other than taking it some place or buying the parts and DIY yourself which can just lead to you “screwing things up”. Pun intended!
good luck
Eric
Eric
Received 3,434 Likes
This is a problem I have never heard of before and it would be interesting to see what the dealer recommends, just for ****s & giggles. The velcro idea is worth trying though although if you use it often it will not hold up very long.
Door Spring/s.
Door Paneling - Springs for Pocket Assembly.
The following 7 users liked this post by Sidvicious7:
I am the Walrus (08-08-2019),
koven (08-08-2019),
maschinetheist (09-27-2020),
Porsche_nuts (08-08-2019),
shammerman (08-09-2019),
and 2 others liked this post.
There are two springs located on the door pocket compartment that are accessible with the door panel removed. I would suggest you inspect the back side of the panel to confirm if the springs are dislodged, broken latch or worn.
Door Spring/s.
Door Spring/s.
I agree! Nice job sidvicious! This forum is brilliant!
I should have known Sid could help, which he did for me yesterday in regards to the memory button surround piece. Here is a good video to help removing the door panel:
Sid is awesome. Seems to always find the answer!
Door Spring/s.
Door Spring/s.
Did you put the "soundskin" on as aftermarket? Why - to reduce outside noise or to add to the audio inside?
Where else did you add it?
Love you guys
I used to be quite frequent with TRF (The Rolex Forum) but I am no longer interested in there anymore. 5 years ago, we used to talk about mechanical movements or horological history, nowadays only whiners and bitching about AD and prices and values and it got old and boring.
Rennlist over the years are totally opposite beside a few threads about market values and help first timer getting the right car, you guys are super helpful with little things like spring in the door panel. Love it.
The following 2 users liked this post by gotgolf52:
CPL55 (09-27-2020),
I added the Soundskin only on the back side of the door paneling to improve the sound quality of the audio primarily. The Soundskin product I used is thinner and reduced weight specifically made for car door installation. Did it help? In my opinion it improved the sound coming from the door speakers and at the same time reduced the road noise.
