Maximum Speed with bike on roof?
Might be more than you think. I've seen a test that suggested that running a loaded bike rack cuts your fuel economy by about a third on the highway. Even an empty back rack costs about 20%.
usccharles (08-04-2019)
No way it is that high. Certainly it should reduce mpg though. I had my bike on the 911 for a 1200 mile trip and I averaged over 29 mpg surprisingly.
So I finally have an opportunity to do a road trip with my bike next weekend.
I have OEM Porsche rack and Porsche road bike mount.
I’ve never driven with a bike on a roof rack and after doing my first test install I’m a bit worried about how fast I can drive. Any advice from roof rack regular users?
What is maximum mph I can drive? Can I do 100mph? I’m on a 500 mile round trip ride.
Thanks in advance and and any other advice I may need during my trip will be much appreciated!
I had had to put a couple rubber dots to get rid of vibration when no bike is on the rack.
usccharles (08-05-2019)
Here are some wind tunnel results for a Buick TourX that were measured recently:
One of the main reasons I like my Seasucker - you can have it on and off in a minute or two and it stows easily in the frunk. I have the mini-bomber that holds 2 bikes - has 4 vacuum cups that each are pull-rated for 210lbs. (plus you have a 5th and 6th cup for the rear wheel support). I'm not worried about the bike holding. Additionally, if you have a sunroof, you can easily see the priming piston and recognize when you need to give them a few pumps (if you've had it on the roof for a while). It's a great system and I can fit a 700c road or cyclocross wheel in the frunk when the bike is on the car - and have plenty of room in the backseat for a wheelbag for an extra pair.
Without knowing how fast subshooter was driving and comparing that with the mileage of the car driven at the same speed without the rack, we don't really know much. A bike has low frontal area, but a high drag coefficient because it has lots of components the air must flow around. Flowing around six 1-inch tubes in a row is probably as draggy as six 1-inch tubes side-by-side.
