Any concern with Sport Plus all the time?
I find I like Sport Plus mode more than Sport, as it seems the most responsive and also doesn't have the exhaust pops and cracks in Sport mode that can be a bit too much for my taste. I've read that Sport Plus can get the turbos really hot with the anti-lag since it always gives them a little fuel. Is there any concern with using Sport Plus all the time? Ideally, I think a Sport mode without the exhaust pops would be best. I've tried Sport mode with PSE disabled but the exhaust doesn't sound as good. I have my individual mode set to PSE on and auto stop disabled - which sounds pretty good but isn't as responsive as Sport or Sport Plus. Thanks
You might have too much fun, that's bout it.
PDK or manual?
Manual no problem. PDK I wouldn't do it.
I'm in sport plus 99% of the time. The throttle response is much sharper and I find rev matching easier.
Received 5,410 Likes
In Sport Plus, the oil is always going to be cooler, so, the downsides (for some may be) are:
1) Lower MPGs. You don't achieve the highest MPGs until the oil is in the +215 range
2) Since your oil is always running cooler, you're never going to cook off water in your oil.
On my manual 991.1 the oil is always about 194-198 in Sport Plus and in the 228-232 range when everything is hot in normal mode.
Whatever...you bought a porsche...drive the crap out of it in sport plus and love it
To expand on this a bit for the OP...
My limited understanding is the way Porsche reduces turbo lag is by leaving the throttle partially open but cutting off fuel delivery. The partially open throttle lets air pass through the engine, which keeps the turbos spooling higher so they require less time to get spooled up very high when called.
Basically, it's doing the opposite of what you (the OP) were expecting. It's removing fuel to keep the turbos spooled. Cool, right?
I did an experiment last week where I drove home from work in Sport+ mode (surface streets). PDK in auto. It was interesting and different than my old 991.1. My old car would definitely hold gears, with maybe the exception of 1st. My 991.2 seems different. In Sport+ it adjusts to how you are driving. In stop and go, it doesn’t hold to redline. If you’re on it, different story. Shifts weren’t quite as rude as my old car. Need to play with it more.
Basically, it's doing the opposite of what you (the OP) were expecting. It's removing fuel to keep the turbos spooled. Cool, right?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Been running in Sport+ (car has the manual gearbox) a lot lately, and I notice that even anti-lag seems to be smart—keeping 1psi going when I am on it but letting the turbos go to zero psi/vacuum when I am not.
Have to say I like the car better in Sport/Sport+ but still wish the auto-blipper was its own setting. That said, if you're on it with your heel-toe, it too seems to let you do your thing. Of course, it's there when you get it slightly wrong or are that bit late...which makes me wonder if it's assisting even when you think you've got it.
