Thoughts about service
I just got my car back after having water pump replaced. When I got car back they had put almost 30 miles on the car and also reset the long term tracker which tracks the g's on the car, fuel mileage, top speed, and mileage. This is both suspicious and annoying.
I really don't mind if the tech properly warms up the car and drives it energetically after engine work. But it is not cool to be resetting stuff on my car. I also have an MT and am always concerned about clutch abuse. Would this bother you guys?
Could be proper procedure to test out the water pump. Get the car fully warmed up, WOT tests. Didn't check my odometer when mine was replaced. As far as the trackers being reset.. It happens.
Does battery disconnect reset?
Sure. When you swipe to that menu and hit reset it's a conscious act. I only noticed because of mileage. And I don't mind if he has to do WOT runs. I fully expect that. And I'd expect an appropriate warmup although with current air temps oil temp is up pretty quick. And with the worn tires I currently have on car, it would be tough to beat the values I have on the car. So I don't get the reset. I'll just instruct no reset next time.
Could be an interesting discussion with the service manager. Just an inquiry and a request to not have that type of data cleared. And say that you want to know what they are doing with the car over such mileage. The service mange should be totally OK with that.
30 miles. i would be suspect. and i would call the service and ask them to justify the 30 miles. ask them if it is justifiable in their eyes and why. maybe they did have to do some WOT long drive testing. those would be proper justifications. but if the service required doesn't require a 30 mile drive, then you have every right to complain. and if the service guy gives you bullsh*t answers, don't go to him anymore ,and going forward, like you said, request that they not reset anything and to let you know in advance if there needs to be extended driving for the service. my car didn't even have 30 miles on purchase.
30 miles sure sounds excessive. Do you need to do 30 miles to test if the water pump will not leak? Doubtful.
Sure sounds to me that they took your car for a little joyride.
Call your SA - be interested to hear the cockamamie story he comes up with.
Received 5,410 Likes
It would be helpful to know your location.
Did they also do some software/firmware updates? That would reset some of your settings.
My car, in Sport Plus, with the 3rd radiator (Power Kit), can easily take 10 miles or more to come up to full operating temp, so if they put "almost" 30 miles (how many actually......24........28??) on your car, that does not completely surprise me. Again, knowing more about your location, and the area around the dealership would help.
Would definitely have a discussion with the manager. I had a car at the dealer waiting for a window motor for two weeks. When I drove away the speedometer wasn’t working. At least you know the mileage.
Is it really worth your time and effort to go through the process of having a discussion with the service manager, making the determination if you do / don't believe the explanation, decide if you want to accept his explanation, blah blah blah.... all for a few excess miles?
Your life will continue just fine, your vehicle is backed by Porsche's warranty, etc.... it's your vehicle and of course there are intangibles that go with this.... but again, is it really worth your time? An explanation ain't gonna change the current state or your car, and seems like you're satisfied with their work barring the few extra miles and a reset....
subshooter (07-20-2019)
CSK 911 C4S (07-19-2019)
When the water pump is replaced, the coolant system is compromised. The proper procedure includes a coolant system flush. The thermal management system on the 991 is very-very sophisticated. An extensive drive cycle is required. So again, 20-30 miles is nothing to get worked-up about. To me, it sounds like the shop did a thorough job.
I expect the drive is to make sure they got all the air out of the system ( not to check for leaks).
Have to get everything up to temperature and flowing to all circuits to do that.
