Ask Amp
Ask Amp
Hi trying to remove Ask amp on 2015 model
The problem is when I pulled the carpet back, there is a metal plate covering the amp.
This is held by security shear head bolts x2 and x2 10mm conventional bolts
Does anyone have a good way to remove security bolts
thanks
thanks
Sorted
Got to the bottom of this
UK issue here we require a VTS security system, so its mounted under the drivers seat (Rhd)
They then add a metal cover and security bolts
under the carpet
Used Urwin stud/bolt remover in a drill
Now to fit Mosconi amplifier
under the carpet
