991 PDCC vibrations?
Old Jun 20, 2019 | 08:34 PM
Wasserkühlung's Avatar
Wasserkühlung
Default 991 PDCC vibrations?
Have a 2012 991 Carrera S Cab with Porsche Dynamic Chassis Control. Vehicle has just over 100k miles and is making a nasty vibration/chatter that resonates through the entire car between 2700-3500 rpms. Put the vehicle up in the air and found the noise coming from what looks like the chassis control lines. The lines are vibrating in between the gas tank and front compartment tub. No faults in the system. Getting an appointment at Porsche but wanted to see if any else has experienced this concern and knows a quick fix. Using my scanner I am getting around 8 bar pressure at all four corners of the PDCC.
Any help is appreciated
Old Jun 20, 2019 | 08:56 PM
worf928's Avatar
worf928
Report back on what you find.
Old Jun 20, 2019 | 09:09 PM
Wasserkühlung
Will do. Going to dealer tomorrow morning for diagnosis.
Old Jun 21, 2019 | 08:57 AM
CSK 911 C4S's Avatar
CSK 911 C4S
Wonder if the pump died or is dying.
on having 100,000 miles.
Old Jun 21, 2019 | 03:31 PM
worf928's Avatar
worf928
on having 100, 000 miles.
Should’ve had ... 2? PDDC fluid and bottle changes by now right?
Old Jun 21, 2019 | 03:47 PM
CSK 911 C4S
The interval is every 60K along with the serpentine belt.
Old Jun 22, 2019 | 01:54 AM
Mojo.K's Avatar
Mojo.K
What did it end up being?
