991 turbo wheels on c2s?
Found a nice set of 991 turbo sport classic wheels. Will these fit on a 991.1 c2s (narrow body)? Front looks to be the same but rear is 11.5 ET 56 w/305 tires. Main concern is sticking out too much and/or rubbing.
Search on offset wheel calculator. The 1010 one allows for inputting of current wheels width and offset and then the new and they tell you if the wheel will retract or extend from both outer and inner edges. Then you can decide how many mm is acceptable.
I think pushing this far out would be too much - hard to tell if the tire would hit the fender. Even if it fits worried it would look odd. Anyone with actual experience putting a turbo or c4s wheel on a c2s 991.1?
I did it with a 996.1. I bought the turbo wheels from the dealership. They said it would work and they were correct. Try calling your dealership service department real quick?
