PIWIS from China
I can solve that for you with alot less pain.
This Japanese company makes the software override which all you have to do is plug into your OBD port to "activate" and your stop start will be permanently disabled. If you would like to reverse it when you sell the car, just plug it back into the OBD port and the feature will be re-enabled.
Caveat, it works and is registered with the car you plug the OBD port into. You can't buy 1 product and try to do it on multiple cars, won't work. Smart for them as it prevents people from buying once and sharing with their friends.
Plug Concept ISC - You can buy it from Amazon Japan. If you can't buy it and want it - Drop me a note, I will get it for you.
Id like the permanent elimination of Auto Stop/ Start,.
Also the 5 blinks with a touch of the turn signal instead of the PCNA 2 blinks.
Would also love to be able to disable the O2 sensor CEL i get with my catless downpipes.
Might try to sell my Durametric, with 1 Porsche left on it.
Hi all,
Just finishing up six year service, used the PIWIS to reset the maintenance interval, checked for fault codes present, and pending (none), and checked for over revs (none). In my book it was well worth the money. It has paid for itself between the service reset, and the coding on my steering wheel.
If anyone ever needs something done with the PIWIS, just let me know, I work for beer.
Regards
Regards
Hi all,
Regards
Regards
Hi all,
Regards
Regards
I got the beer, you bring the piwis and the chick in your avatar!
