Rear Wing Disable
Im hearing a loud bang, like a rock being picked-up as I drive when the rear wing is moving down.
I think the spring on the drivers-side may be broken.
I don’t have time to get it fixed right now, so I was hoping to disable it.
I can keep it raised, but not lowered.
To the right of the engine compartment, right under the wing, there are two plastic trim panels. You need to raise the wing and open the engine bay to access them. Once you take out the fans, and the two trim pieces on the Passenger side (Left) there is a cable there. You can unplug this and it will disable your wing, BUT you will most likely get an error code on your dash.
Another way is to go the dealer and ask if they will deactivate your wing with their PIWIS.
