Wheel spacers for GTS
Old Jun 13, 2019 | 08:28 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Originally Posted by DBH
There were NO spacers as standard equipment on GTS models. You could however order them from the factory as an option.
When I ordered a Boxster S in 2008 it had a 5mm spacer option; however, that option was not available when I ordered my 2019 Targa GTS last July.
Old Jun 13, 2019 | 08:37 PM
V999's Avatar
V999
Bob, did you ever post photos of your car with the 7mm spacers? If so, can you point me to them?
Old Jun 13, 2019 | 08:54 PM
DBH's Avatar
DBH
They were the last half of 2017 ('18 MY).
Old Jun 13, 2019 | 10:32 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
I had not posted any so here are a few I just took, 7mm front/rear. The rear tires are pretty much even with the fender lips and the fronts are tucked just a little but to make the same as the rear I would say at least a 10 is needed:
Old Jun 22, 2019 | 10:28 PM
V999's Avatar
V999
Looks good. Thanks.
Old Jun 22, 2019 | 11:43 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Needless to say the bottom of the tire is much further out when the top it flush with the fender lip, which will throw more crap up at the car. By the having the fronts slightly tucked they look better and help keep the side of the car in better shape over the long run, but I do have PPF.
Old Jun 27, 2019 | 04:42 AM
cryptical1200's Avatar
cryptical1200
I have a 991.1- 5mm spacers came standard with the 5-lug option as the CL’s stuck out more due to offset or were .5” wider than the 20” S wheels-I can’t remember. Spacers were dropped on the 991.2 GTS w/ 5-lugs
Old Jun 27, 2019 | 09:27 AM
BGLeduc's Avatar
BGLeduc
Good info. I just acquired a '15 991.1 GTS with 5 Lugs, and it has the 5mm spacers. They were not listed on the build sheet, so I assumed that they were either standard or a PO added them. They are discussed in the owners manual and on the "Good to Know" app.
Old Jun 27, 2019 | 09:55 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
I'd be interested in seeing the difference between the .1 & .2, side by side, to see if the wheels are tucked the same amount.
Old Jun 27, 2019 | 10:17 AM
BGLeduc's Avatar
BGLeduc
You gents have very sharp eyes if you can eyeball the difference between no spacers, 5mm, and 7mm.
Old Jun 27, 2019 | 09:28 PM
DBH's Avatar
DBH
That's what I got...
Old Jun 27, 2019 | 09:39 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Just add a set of 7mm spacers as I did on my .2 GTS with 5 lugs. As I said, the back is perfect and the front just barely tucked, which will help prevent too many rocks from chipping the side forward of the rear wheels.
Old Jun 28, 2019 | 12:06 AM
cryptical1200
Whoa-how did I miss that?! Indeed they are on the app....Great to know! Thanks a lot. I ended up going with ECS 10mm rear and 8mm up front. Will post up after I throw them on.
Old Jun 28, 2019 | 12:09 AM
cryptical1200
Looks great Bob. Just enough. Thanks for the photos sir!
