MAP Sensor Location Please
Old Apr 28, 2019 | 07:20 PM
cdelrosario's Avatar
cdelrosario
Default MAP Sensor Location Please
Hi all,
I am trying to locate exactly where the MAP sensor is located on our cars. I want to change mine due to a code being thrown.
I know there’s a YOUTUBE video of it allegedly under our frunk, but that is wrong. There is another picture that shows the sensor to right of Oil filter but it doesn’t actually show the sensor. I have searched the internet with no luck.
Has anyone changed their sensor? There are no diagrams on Internet.
Thanks!
Old Apr 28, 2019 | 08:00 PM
Dom991.1's Avatar
Dom991.1
Pretty certain this is it in the photo below? It is on the plenum between the “runners”. Never took it off on my 991s but I HAVE removed it (to replace plenum) on a 981. Easy on a 981 once you have the engine cover off, 991 seems like it would be substantially more difficult as you don’t have access from above but, rather, from “in front”. Also included a picture of what you see with engine cover off (which is pretty much just the TB). Good luck!
Old Apr 28, 2019 | 09:34 PM
Rennolazine's Avatar
Rennolazine
I didnt think the .2 had a MAF sensor. Subscribed for right answer
Old Apr 28, 2019 | 09:51 PM
Dom991.1's Avatar
Dom991.1
Originally Posted by Rennolazine;[url=tel:15805029
15805029[/url]]I didnt think the .2 had a MAF sensor. Subscribed for right answer
I guess I didn’t ask if this was a .1 or .2. I know for certain the 991.1 using a MAP (based on pressure) as opposed to a MAF (based on airflow). Below is a diagram confirming the location I had indicated for .1, don’t know about .2!(I would THINK it has a MAP sensor as well but not sure??), good luck!
Old Apr 28, 2019 | 10:50 PM
cdelrosario
Thanks Dom...that’s it! I guess no one has ever changed it. I’m getting a MAF code so I wanna change it as it’s only a $33 part. I bet dealership would charge at least $600. Would be great if I had some access without having to take out plenum. We will see. Thanks again.
