Pink fluid leaking
Old Apr 21, 2019 | 11:08 PM
arvindkst's Avatar
arvindkst
3rd Gear
Default Pink fluid leaking
Need help identifying the cause for the leak. It’s a pink fluid below the engine bay of my 991.2 thanks
Old Apr 22, 2019 | 11:32 AM
tubernator's Avatar
tubernator
I just had this at 10k miles. Mine was water pump, replaced through warranty.
Old Apr 22, 2019 | 11:35 AM
JSETarga's Avatar
JSETarga
water pump
Old Apr 22, 2019 | 01:28 PM
DBH's Avatar
DBH
It's definitely coolant. One of two things: 1) overfilled overflow tank purging heated (expanded) fluid or 2) water pump.
Old Apr 22, 2019 | 02:14 PM
arvindkst's Avatar
arvindkst
3rd Gear
Thank you all.
Old Apr 22, 2019 | 04:28 PM
Cyberbug's Avatar
Cyberbug
check this thread and fill in the survey
https://rennlist.com/forums/991/1112...-replaced.html
