Took in for summer tire swap out & next day blowout!Look at the pic & share thoughts
Received 5,413 Likes
Do they want you to replace both rear tires or just the damaged one?
They didn't recommend one or the other. just asked if i wanted to do one or both. I was hoping they would offer to split the cost and each do one...but no such luck. I told them just to replace the one for right now. I was just so irritated at the time...probably should have just done both. The tires only have 9k on them.
After you get back up & running again, and the vibration is cleared up, pay very close attention upon aggressive accelerations. If anything wonky is going on, it's because the new tire is 9-10/32's and the old tire is significantly below that differential threshold.
Anyone else first think that looks like a plug ejected itself...?. The threads pulled the way they are, the deformed rubber to one side only -- wouldn't you think this was a plug job that failed? Wobbling feel could have been the plug partially out. I mean, they do fail, right?
Well, by 911 standards, that's a ton of miles. And looking closely at your pic in post #1, I see other nearby cuts in the thread, so you probably did run over something.
9k is a TON of miles for the rears. You don’t mention the model (unless I missed something) but if it’s 991.1S then you have PTV (or it could have been optioned on a base) and if you do, in my experience, rear differentials ride very poorly with mismatched tires (or ones with significant treadwear differences). Food for thought...
As suggested you should replace the 9000 mile tire so you have a new set on the rear , buy it from TR and save yourself a few dollars ( have it shipped to one of TR installers and have it road forced balance both of them
Get both rear tires replaced and keep the "good" old tire as a back-up spare - just in case. The fronts generally last the life of two rears. So the next time around you can get four new tires.
