Help! Weird bumpy texture on lower side of brand new GTS
#31
Received 3,460 Likes
Unless you have wet sanded the car (or had someone do it) there is orange peel on your car. You may choose to say there isn't because you have less than some other car(s) you've had or seen or you don't really know how to identify it but it's there. Look harder at the right angles on the right panels and you'll find it. All modern factory robot painted cars that were not hand sanded during the process or wet sanded for perfection afterward have orange peel. All.
#32
I'm pretty sure Porsche has found a fix for the uniqueness of that "bumpy" rocker panel. Most of the newer ones I've been seeing on the showroom floor now seem to have matching orange peel on the rest of the car.
I'm not even joking. There was a GTS Cab right near my service guys desk when I was in there a few weeks ago, and I told him if I had ordered that car special, I wouldn't accept it with that paint job. Every model in there had atrocious orange peel at least somewhere on the car.
As for the rough texture at the bottom of the rockers, very normal. That area will get thrashed with debris, and if it's like mine, up close it'll get full of little chips and such. Good thing they made it so rough or who knows how bad it would look. That area is one of the rare if only areas of the car I'm not OCD about, as being OCD about it would drive you insane. You won't notice it from any distance and thankfully Porsche already made the texture rough, so it's nothing to be perfectionist about.
#33
That textured stuff below the doors is weird. Surprised that was the solution. Seems to work.
