991.2 Spoiler Stuck Up
Old 02-27-2019, 07:38 PM
rhao97
6th Gear
rhao97's Avatar
Unhappy 991.2 Spoiler Stuck Up
My 991.2 4S just encountered this issue: I notice that my spoiler is up when I was parking, so I tried to lower it by pressing the spoiler button. I hear some noise from the spoiler and it lowered a little bit. The spoiler button keeps blinking slowly, but the spoiler does not go down anymore. When I press it again, it rises up and the light keeps on(which is normal).
Usually, when I switch from my "Individual mode" to normal, the spoiler lowers itself automatically, so I tried to do that, but the spoiler did not react at all.
I checked to see if there's any object stuck in the spoiler, but I could not observe any by my eyes.
Has anyone encountered this issue?
James0029 (07-18-2021)
Old 02-27-2019, 08:31 PM
Psorcery
Psorcery's Avatar
Try holding the button down
Old 02-27-2019, 08:36 PM
feh
feh's Avatar
It’s normal. It only closes while moving, when you click once. When stopped you have to keep holding it. It’s to prevent fingers/body parts/small animals from getting caught.
The following 2 users liked this post by feh:
Dutchman647 (06-26-2024), James0029 (07-18-2021)
Old 02-27-2019, 08:40 PM
rhao97
6th Gear
rhao97's Avatar
Thank you so much!
Old 02-27-2019, 09:41 PM
V999
V999's Avatar
Could be worse. Could be one of us Porsche owners that’s stuck up.
KWP1911 (09-19-2020)
Old 02-27-2019, 09:48 PM
Rennolazine
Rennolazine's Avatar
Permanent J Rod
Old 02-27-2019, 10:11 PM
V999
V999's Avatar
If your spoiler remains up after 4 hours, call your doctor?
The following 2 users liked this post by V999:
Dutchman647 (06-26-2024), HB PCH 911 (07-24-2024)
Old 02-27-2019, 11:19 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,235 Likes on 747 Posts
Use 91 octane gas only
Old 02-27-2019, 11:26 PM
Fbrooksr
Fbrooksr's Avatar
Default When you're hot, you're hot!
When I owned the 997.2, I had read somewhere that if you shut your engine off and the engine is still very hot, the spoiler will stay up to enable cooling. When it reaches a cooler temperature, it will lower automatically. Anyone able to confirm or deny my recollection?
Old 02-28-2019, 12:30 AM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
I went to hit my front axle lift and hit the spoiler and spent a good two minutes figuring out I had to hold down the button. And yes, on the 991.2 the spoiler will go up to air cooling.
Old 02-28-2019, 09:19 AM
Cyberbug
Cyberbug's Avatar
If it doesn’t go down with in 4 hours your have to see a mechanic
The following 2 users liked this post by Cyberbug:
AdamSanta85 (07-15-2020), HB PCH 911 (07-24-2024)
Old 02-28-2019, 02:08 PM
Fbrooksr
Fbrooksr's Avatar
Default 4-hours
Or, call the neighbor over.
Old 02-28-2019, 09:03 PM
StormRune
StormRune's Avatar
You are right about it being a 997 thing, but not in the 991.
Old 02-28-2019, 10:37 PM
THPorsche
THPorsche's Avatar
Stop playing with IT
Old 03-01-2019, 11:40 AM
digits
digits's Avatar
Now I'm intrigued
Quick Reply: 991.2 Spoiler Stuck Up
