SC rev match for first gear 2019 911T?
Ok, I just proved the 2-1 rev match today.. earlier poster was correct, it will down shift 2-1, you just have to be going fast enough for it to do it
I never mentioned that I'm "starting off'" in 2nd. Don't know where you got that impression.
At slow speeds, not "starting off", I don't find a need to drop to 1st, 2nd does quite well.
On another note, rev matching is loads of fun, but the drivetrain components are wearing on up and down shifts, so maybe for fun but not all the time. There's no free ride.
I'm not quite sure of what you're trying to say, "starting off", is that from a dead stop? If it is, it's not what is being discussed here, the question is does rev match happen in a 2-1 downshift while the car is moving. According to some, it happens somewhere around 15 MPH.
Sorry, misread and thought you were starting in second. What components are wearing? Rev matching is WAY easier on the clutch ....if done correctly the clutch isn't needed. As for wearing out components.....everytime you start and drive the car you are "wearing out" components.
You have to use the clutch/drivetrain to upshift, however, you don't have to use the clutch/drivetrain on downshift for "less spirited" driving when slowing down. Brake pads/discs are easier/cheaper to replace than clutches/release bearings/pressure plates/flywheels and the like.
Happy driving!
If you're engaging/disengaging the clutch/drivetrain on upshift that's wear on the way up, if you're engaging the clutch and drivetrain on downshift that's wear on the way down.
Happy driving!
Happy driving!
Your "parking it" doesn't relate to the wear issue as to actual driving. Why don't you pose the question to an auto tech and see what they come up with?
Have a good one.
Really think that drivetrain wear isn't greater by engaging the clutch both up and down as opposed to using it just to upshift? Don't know the answer to that thinking.
Have a good one.
Have a good one.
Have a lovely day
Get back with me when you've got your supporting data.
BTW, today I was driving down the road on Sport with my windows down, shifting up and down and enjoying the ride, so your "guess" is completely wrong. And "guess" what, I'll be doing that tomorrow as well.
Nice to have had the discussion.
"Does not wear clutch at all". Do you know this as fact? You don't, unless you're able to produce facts to back what you wrote, you statement is purely empirical, so at best it's only an opinion. Your absolute statement is a poor basis for discussion, because you have to prove it. You need disassemble a sufficient number of identical model, in use and wear as well, manual transmissions and conduct a detailed examination on every one. Further, you have to use controlled experiment procedures to isolate that which is being examined, the "does not wear clutch at all" part.
I'm out. You are clueless.
IMO, 911 1st gears are pretty low in both the PDK and manuals, and downshifts to first with either tranny aren't the sweetest, unless moving very slowly. But that's not the speed that most 911s are most frequently driven, so it's not a big deal to me.
Driving cluch-less with a transmission that cost $10k-$20k on the newer cars? That's up to the owner, it's good you feel comfortable doing that.
