Quick Jack for 991.2
#91
I think that the leaking air cylinders have been sorted out. But a good recommendation is to put 50 psi in the air cylinders and check them over the next weeks to ensure they are holding pressure.
#92
Mt 7000TLX arrived last week. I used it to change into winter tires on my 991 and my wife's MB E400 wagon. I needed the X to reach the E400 jack points. With the 991, it does fit between front and rear tires with about 2" to spare, but must be positioned almost touching the rears, or it contacts the fronts as it lifts. Also note that I positioned the lifts "backwards" as people have described for 911s, so the car's center of gravity stays within the lift base plate.
911hammer (12-08-2022)
#93
