alignment
Old Nov 13, 2018 | 04:48 PM
mymac's Avatar
mymac
Default alignment
I just bought new tires for my 2012.5 CS with 34k, and am wondering about an alignment. Should I use the stealership or have Les Schwab do it? The old tires didn't show any unusual wear they were just worn out.
Old Nov 13, 2018 | 04:51 PM
LexVan's Avatar
LexVan
I'd do an alignment.
Try to find a Special at your dealership. A fair price, for a car without RWS nor any cameras for lane assist or adaptive cruise control, is about $300. An indy will probably charge you about $200 min.
Old Nov 13, 2018 | 07:21 PM
eagle1960's Avatar
eagle1960
There's really nothing special about alignment on these cars . Any shop with a modern system like Hunter can do it. I would still want to look for an indy that has Porsche and/or other high end car experience. I have had my 987S and 997S alignments done by a local indy tire shop for $80. Will take the 991 when it needs it.
Old Nov 13, 2018 | 07:25 PM
LexVan's Avatar
LexVan
This is just not true anymore. Especially on 991 cars with RWS, and all the cameras and sensors for certain options.
Old Nov 13, 2018 | 10:47 PM
PCA1983's Avatar
PCA1983
If the tires you replaced had perfect wear, i would not get an alignment If there were uneven wear patterns on this tires, not attributable to tire pressures, then i would get an alignment ment. Without RAS, alignment is not that complicated for a good indy Porsche shop. Otherwise, find a Porsche dealer with a special. And check their prices. Labor rates do vary among Porsche dealers, even in the same geographical area.
Old Nov 14, 2018 | 03:17 AM
Papa Fittig's Avatar
Papa Fittig
If my old tires do not show any unusual wear, I never do new tire install alignment these days. This is just because too many times I had my alignment done wrong causing real alignment issues instead of fixing potential alignment issues, Dealers included. And some of them are not doing it themselves, but rather have a 3rd party doing it. I
I also hate to do tire balancing for the same reason, but there is no way around it.
Once I even came back to a shop who just did the "balancing" and push them to prove they calibrated their machines properly. Sure it was not done right. They apologized, re-calibrated their machine and re-balanced my wheels with me present. It sure helped, but would you jump over the hoops all the time? And with alignment you can't tell if it is done right or wrong right away. So, no, no alignment unless really needed for me.
There is or rather was one shop only I know of in my area which always did both jobs perfectly. It was owned by a Porsche owner and ex Porsche mechanic. New equipment and clean. Unfortunately, not too many customers were willing to pay high price he charged. Its shame he is gone.
Old Nov 14, 2018 | 04:17 AM
Valvefloat991's Avatar
Valvefloat991
I'm just curious what do cameras or adaptive cruise control have to do with alignment?
Old Nov 14, 2018 | 04:23 AM
LexVan's Avatar
LexVan
I don't know. But the dealerships have different prices based on certain options.
Old Nov 14, 2018 | 04:31 AM
HenryPcar's Avatar
HenryPcar
If your old tires are wearing evenly, and your steering wheel is level, and your car does not pull to either side, you really don't need any alignment.
Old Nov 14, 2018 | 08:00 AM
Valvefloat991
Interesting. I can't imagine what difference such options would make to the wheel alignment specs or adjustment difficulty. It's not like those sensors are mounted on the suspension components.
Old Nov 14, 2018 | 09:52 AM
Mark993TT's Avatar
Mark993TT
Surely the 991 can’t be more challenging to align then a 993 ...
Old Nov 14, 2018 | 09:57 AM
LexVan's Avatar
LexVan
But how many shops used, and had, the proper kinematic toe tool from Porsche? Not many. But, I liked your comment.
Old Nov 14, 2018 | 10:05 AM
MaynardZed's Avatar
MaynardZed
$80 at an alignment shop for my 991.1, but I do a custom alignment for the track that a dealership probably wouldn’t want to do anyway. They didn’t seem confused and everything was fine afterwards which makes me think there’s nothing special about the cars without RWS at least?
Old Nov 14, 2018 | 10:12 AM
LexVan's Avatar
LexVan
Did your rear tires last 34,000 miles? That's amazing. Unheard of.
Did your front tires last 34,000 miles? That's more "in-line", since they can take a double stint.
Old Nov 14, 2018 | 10:34 AM
Mark993TT's Avatar
Mark993TT
The good old 993. You just had to drop the “K” word to know if your Porsche specialist or dealer knew what they were doing. ;-) Luckily I have nothing but good experiences with my local specialist (later dealer).
