I want to make sure I'm using this correctly on a car I picked up this week.
Just plugged it into an outlet and then plugged into the cigarette lighter.
It initially showed the power light on and I then pushed the "mode" button until it toggled to the "car" icon lighting up ?
Anything else I need to know ?
Most instructions seem to indicate plug first into the car outlet, toggle to car icon on charger, then plug into power outlet.
Originally Posted by Papa Fittig
Yes, this is correct.
That means you can’t leave it plugged into the wall outlet and each time you reconnect you have to connect two things.
Kind of a pain.
What happens if it’s plugged into the wall first and then the cigarette lighter ?
ouch. Almost as bad as driving away while it’s still plugged in. Ask me how I know. Lol
I have two Porsches on maintainers. After driving out of the garage with each car while still plugged in, I ordered red "REMOVE BEFORE FLIGHT" tags, and attach them to the keys with a carabiner. When not attched to the keys, they are on a small wall hook next to the charger.
Mine goes from wall outlet into into 12v socket through open driver's window. Impossible to drive out while unplugged
I made a slip noose type knot in the charger cable that I hang around the shifter when connecting it to the footwell socket. It makes a good tactile and visual reminder...
