Suncoast sells clear side marker lights the are easy to swap for $120 https://www.suncoastparts.com/produc...1LEDSIDES.html
I like the look better than amber but on my configured 991.2 (C2S) ordered a couple months ago, the photo shows it already has the clear side markers!
I'll attach a photo copied from the configurator of my car.
Is the photo wrong & will I actually get the Amber colored ones?
Thanks!
Seems the photos are not accurate.
Very misleading, IMO.
they are side markers... pretty certain that the clear vs amber issue does not rise to the level of “very misleading” given that the only people who care about such things are in this forum. We could take a poll, I could be wrong about the scope and long term PTSD implications of this national crisis.
BTW, the parts counter at your dealer also sells clear side markers.
Stock photo is often of a EU spec car. I wouldn't worry about your car being equipped incorrectly from order specs.
If you end up buying the clear markers yourself, be sure to get the LED versions. There is a bulb version, too (for less money), but it doesn't look as good because you can see the orange bulb behind the lens. The LED looks clear/white throughout, until turned on.
There are actually 4 different versions of the front turn signals that I know of:
Amber (standard bulbs)
Amber LED
Clear (amber bulbs)
Clear LED
All will illuminate with an amber color, but IMHO the Clear LEDs are the way to go. I was lucky enough to find a lightly used set on Ebay for $60 when I had my Cayman, and then transferred them to my 991 before I sold the 981.
