Wax before PPF
Old Oct 13, 2018 | 03:10 PM
Dkk16's Avatar
Dkk16
Default Wax before PPF
I am having the front end PPF installed in a couple of days. Shoul I give it a quick polish and wax before I take it in to enhance the look? Or wil it even matter?
it is a 2018 CPO with 2K miles on it, I picked it up yesterday.
Old Oct 13, 2018 | 03:18 PM
user 6298402424's Avatar
user 6298402424
PPF installer should be doing a polish (stage 1,2 or 3 depending on condition of paint) on the car before applying the PPF. So no need to wax prior.
The reason for the polish is that you want your paint surface to be as perfect as possible before the PPF is applied.
Old Oct 13, 2018 | 03:20 PM
Penn4S's Avatar
Penn4S
No matter how new the car the installer should do a complete detail or correction before PPF is applied. PPF is a window into what was done to the paint before application. The better the paint the better the final look.
Old Oct 13, 2018 | 05:37 PM
SoCal C2S's Avatar
SoCal C2S
I had a full paint correction, Suntek PPF, and then Ceramic Pro Gold done to my 911 and Macan. That way the paint is as close to perfect before anything is done.
Old Oct 13, 2018 | 07:19 PM
Rezus's Avatar
Rezus
Polish yes but too much wax is actually a problem preventing the film from adhering properly. I polished and waxed my M3 before applying the film and installer told me he had to remove the wax since film was not sticking. I suppose one layer is fine but I went a bit nuts with the wax putting down 3 layers.
Old Oct 13, 2018 | 08:28 PM
Penn4S's Avatar
Penn4S
Correction is better than you layering wax on it. The installer will have to strip it anyway. The shine under the PPF comes from the PPF. A coating after PPF does both.
I coat my car PPF and painted área with Gyeon Can Coat. I can Coat 2 times a year and basically clean my car by just spraying it.
Old Oct 14, 2018 | 06:49 AM
Cyberbug's Avatar
Cyberbug
If you picked a good installer then your installer knows best.
Btw..there should be nothing on the paint before PPF install, car is cleaned thoroughly, any paint correction is done prior to install and any polish or ceramic coating applied after.
Old Oct 14, 2018 | 07:57 AM
Rennolazine's Avatar
Rennolazine
I waxed mine only to potect the paint during driving before ppf. I couldnt wait a week with the car just sitting. However, like others have said, the wax needs to come off right before application otherwise the film may not adhere correctly. I used dawn soap followed by spray down with 50% isopropanol. If your installer preps the car you are all good, but make sure to ask in advance.
7 Porsche Models That Have Aged Like Fine Wine
Old Oct 14, 2018 | 08:43 AM
LexVan's Avatar
LexVan
You already got great advice by the crew here, but, I just wanted to point out, nothing is done quickly on our cars regarding washing, detailing, and PPF.
Old Oct 14, 2018 | 08:47 PM
Dkk16's Avatar
Dkk16
Roger that! 😎
Old Oct 14, 2018 | 10:49 PM
PCA1983's Avatar
PCA1983
Any good PPF installer is going to first strip it with an alcohol/water blend. So don't bother waxing because it's always going to be stripped before PPF installation.
Old Oct 15, 2018 | 11:05 AM
Speed2000's Avatar
Speed2000
Wax the car so you know where any imperfections or chips are before taking it for PPF. Having wax down makes removal later on much easier. I have never had issues with film sticking to a waxed surface.
Old Oct 15, 2018 | 11:15 AM
StormRune's Avatar
StormRune
Rather than trust anecdotal "it worked okay for me" kind of guidance, I'd suggest following the film makers' reommendations. Here is a quote from Xpel's FAQs:
Waxes, sealants and protectants are typically designed to reduce the surface energy of the paint, making them easier to clean etc. A reduction in surface energy will reduce the film’s ability to adhere to the paint and could cause long term adhesion issues. Because of this, we generally recommend removing these types of products before installation. If these types of coatings are to be used, we recommend applying them AFTER installation of our paint protection film.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
