Porsche 991 Valvetronic
Basic Sponsor
Did you get a 991 without PSE? Or did you get oe with PSE but need more? We have the perfect system for you!!! Check out the Valvetronic Exhaust.
Increase power and save weight with a throatier and deeper exhaust note throughout the RPM range
It can fit to your 991 even if you do not have PSE. We add a key fob to your package that will control the exhaust sound, you can also add it to your home link if you don't want the key fob.
If you have PSE you can hook the system right into the button on the center console.
Fabspeed's Valvetronic Exhaust for the 991 Carrera vehicles saves 13 pounds from the vehicle and improves exhaust flow and power by replacing the factory headers, center muffler, side mufflers, and air box.
The system is made out of T304L stainless steel. We also use the highest quality valves with
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Basic Sponsor
Do you know what kind of valves your exhaust system uses? Simply put; if they’re not from Helical UK, they’re not the best.
Fabspeed Motorsport utilizes the absolute best materials available for our products and that includes valves from Helical Technology UK.
Helical Technology is the foremost producer of high specification engine control systems, manufacturing valves of the highest quality for some of the most technically advanced and difficult applications. Helical Valves are the standard for high performance and are used by all of the top auto manufacturers in the world from Ferrari and Porsche to Lamborghini, McLaren and more.
