7mm 15mm spacers on a C2? need thoughts!!
i had a 991 c4s and installed wheel spacers, 7mm in the front 15mm in the rear.
when i got rid of the car, i kept the spacers.
i now have a 991.2 C2 and ive started to install the spacers on that car. from what i understand they "fit" fine. i concerned about the rears being too thick. ive installed one and the tire most def sticks out of the fender, but not a ton. all of the tread is inside the fender, but the sidewall is sticking out a touch.
i wanted the tires more flush but i certainly dont want it to appear "stanced".
anyone tried this?
anyone tried this?
anyone tried this?
anyone tried this?
That is a .2s with techarts... 7mm rear and 15 front ..
I would recommend 7mm rear and 12mm front.. 15 has slight poke in front
I used similar spacers on prior models, but on the 991.2 the rears sit almost perfectly from the factory... in my opinion. I'd recommend nothing on a 991.2, but 15mm is certainly too much.
