Warning Triangle Installation on a 991.2
Hello,
I could not find a detailed explanation on how to install the warning triangle on a 991.2, so I figure this might help someone...
Here are the part numbers I bought:
The installation should not take more than 30 minutes.
Here we go:
1 - Remove the trunk cover (by pulling the handles on each side).
2 - The two tiny bumps circled below show where the holders will slide in.
3. Remove the top part of the rubber seal to get access to the fiberboard.
4. Here's the left holder. The top arrow show where the fastener goes, the bottom arrow is the part that slides in the small metal holder (see step 5).
5. The top arrows show where the fastener will go, the bottom arrows show where the holders slide in. Note that the holes in the metal holders are not used.
6. Showing how the holders should be installed.
7. The cutting part is fairly easy. The photo below shows the end-result.
For the bottom part (where the plastic holder slides in), push the fiberboard so that it touches the metal holder underneath, and just slice the fiberboard with an X-acto knife.
This step is fairly easy, just make sure to slice the entire length of the metal holder.
For the top hole, see the next photo.
Once you're done with the slicing of the bottom, insert the plastic holder, and locate the hole that is behind by poking with a small screw driver (you have to apply a bit of pressure to go through the fiberboard).
Once you've located the hole, remove the plastic holder and enlarge the hole with a bigger screw driver.
8. Here's what you should see once you've done both sides.
9. Insert the plastic holders, and push the plastic fasteners all the way through.
10. Voila!
11. Looks even better with the First Aid Kit!
Hope you found this useful!
Hoki
- Holder ($9.81): 991-551-801-01-1E0
- Holder ($9.81): 991-551-802-01-1E0
- Warning Triangle ($41.66): 8K0-860-251
- Fastening Screw x 2 (2 x $0.34): 999-507-294-40
Here we go:
10. Voila!
Hoki
Rich_Jenkins (10-03-2019)
I just did this on my 2017 991.2 and it is actually a bit different.
The part numbers are:
holder 991-551-802-001-EO
holder 991-551-801-001-EO
Its the same procedure as above, but only the slot is needed to be cut, there is no hole for the fastening screw.
Bracket holders behind lining
Left and right brackets
The location of the required cut is actually embossed in the lining
Installing the brackets takes a little finesse and effort to slide in
Done!
Done!
Done!
Done!
I believe the first aid kit is #000 722 o41 01 and the strap is #997 551 741 00. Should verify with your local Porsche dealer. I could not get the first aid kit from a US Porsche dealer. had to get it when I was in the UK. May be different now. This was 3 years ago.
I bought mine from Suncoast but they are not carrying it anymore. They have this one instead:
https://www.suncoastparts.com/product/PKFIRSTAID.html
It looks like the new kit also attaches to the liner via a velcro strap. This is a pretty bad design as the kit keeps falling...
