Memory mirror question
I recently purchased a new to me '13 C2S. It has the memory seat option which is working fine. However, every time I return to the car after it has been locked and parked the mirrors are moved. I can move them back by pressing the memory setting but I can't figure out how to set them and have them not change. Any help would be appreciated.
Do you have the memory button with a key on it? If you do, use that button instead of the [1] or [2]. Then it's tied to the key you're using assuming you unlock the car with the keyfob.
Yes, I do. I can try that but not sure why it keeps moving the mirrors and not the seats.
Read your manual about "Auto Memory" function. I think that's what it's called. Could be that your mirrors are set in that and are reverting back to the setting in Auto Memory when door is unlocked.
In Settings, there is an Autosave function. Make sure that is checked. Autosave will remember all settings you have in the car right before you lock it, so it will remember your mirror, seat, radio settings, etc.
