Protection for underside of Frunk?
#46
Received 5,388 Likes
Besides the low risk of a potential dimple or nipple (I just wanted to say 'nipple'), I just like the way the underside looks with the shield. And the 991 shields look so much better than the prior lid liners, when they were the entire surface. Ours on the 991 are just the small area above the cargo hold, which makes a lot of sense.
#47
#48
#49
Interesting post. Few thoughts:
1) Anyone who uses a CA Duster doesn't really care about their car anyways, so what would a few frunk lid dents matter.
2) Further, anyone who would keep a +$300 car cover on the bottom of their frunk cares even less.
Beware if you see in a Craig's List car add:
"Doctor owned"
"I meticulously clean my car with a California Duster"
"Doctor owned"
Speaking of the previous owner.. he bought the car cover. I’d never spend that money on a cover. I wouldn’t even get a cover. Dragging that thing all over your paint to try and get a snug fit (since they make it such a snug fit) is akin to using a CA duster on a car that wasn’t washed for 2 weeks then sat overnight in condensation. I used it once, and was so paranoid putting it on. Putting a metal zipper on it was a genius move on their part, btw. Nothing says “protect your paint” like the inevitable metal on metal clink as you’re trying to get the thing on.
Therfore, it’s become a $300 trunk liner. And it works great as that as it keeps everything in said trunk padded, absorbed, and sitting still in place. Which is why even if the duster handle wasn’t fortunate enough to slightly rub against the “metal padded” part of the inner hood, it would just smoosh down on the “padded” (cover) floor likely before it damaged the hood.
Not saying my dumb *** can’t find a way to eat my words. But as of now, I have other areas which take a lot more concern precedence over the inner frunk.
#50
Basic Sponsor
That was my 1st thought. Why I posted.
If it was $40, it would seem like a reasonable price for something that should have been included by Porsche, as part of the car. For a finished look & to prevent small scratches to the metal underside.
I don't mind a bare naked, sheet metal, inside lid.
The question is...it is a real possibility to literally damage the exterior side of the Front lid. Can a moment of carelessness literally spoil the front top of this beautiful car, requiring you to spend thousands at a paint & body shop to fix? Or is it an extremely rare problem?
If I slammed the frunk lid down, on a sturdy, metal, pointy object... that was a couple inches too high to properly fit in the frunk, would this $200 piece of plastic stop it from denting or puncturing the frunk lid?
I'm not really worried about scratching the underside of the metal.
If we ever run thousands of parts in China, it'll cost you $40.
The only reason the part exists is because it is a common issue
It's not metal, it's aluminum
We don't slam the hood. We rest it on the latch a couple inches from a closed position. We then push down and hope it doesn't take more pressure to do so, than what we applied in the past.
Short of a knife collection, you're covered....
You made a good decision
#51
Ok, I'll chime in-
I hope I never slam the hood.
I won't have the car (My 1st 911) for another month or so. IDK how the lid shocks or struts (assuming there is something that holds up the frunk lid) work yet.
I have had the struts fail on a car b4 that caused inadvertent slamming of the trunk. Obviously once you know this, you need to replace the struts.
#52
Basic Sponsor
The hood is aluminum, so lighter and less stress on the struts. Also more difficult to repair. The earlier 911 struts were undersized, IMO. This is not something you will have to worry about for a very long time!!
Point on slamming hood is that the way you close a Porsche hood just contributes to the problem, as it's not "bouncing" up if an object interferes.
#53
Lidliner: I have never seen you post before so I would like to make a comment/suggestion..
Can you please make your lidliner with a hole so the factory support can still be used during service? I had a custom installer tell me he uses a router to make a hole for his customers.
Is there a reason why it doesn't come this way from your factory to begin with? Just wondering. THX
#54
Basic Sponsor
To answer your question-We did consider this, but install and removal can be done in under 2 minutes. Simply tug at a corner and work your way around. This can be done multiple times with the same retainer clips, leaving them in the liner. You can do it on the service drive, or just inform the tech how to do it properly. Also, there is the aesthetics. A hole just doesn't look right...
There is a video of install/removal on our site to see it being done.
Really appreciate the great comments and question
#55
Thanks for responding At the very least I think you should offer the option to customers. For me, I would never bother pulling on and off the lid liner multiple times a year for service year after year. It is plastic and at some point it could bend/warp and certainly the clips will fail after a certain amount of installs and removals. As far as cosmetics, this is something that is rarely seen, on the underside of the hood, so cosmetically this is a non issue for me. At least offer the option to customers. I bet you will sell 80% with holes compared to 20% without.. I have to wait to go back to the custom installer to use his router to get the hole in the exact spot and perfectly round. I will post pics to show how it looks at some point..
#56
I drilled a hole in my Lid Liner some time ago and the yellow hanger used to support the battery cover has to be modified because the hook portion is not wide enough to hook into the new drilled out lid liner hole because the original hole has now essentially doubled in thickness.
#57
Basic Sponsor
We also considered a hole with flush mounted plug and will keep you posted on any alterations. Appreciate the input!
#58
Are there any photos of the factory support being used while servicing the 911? As I understand it, w/o the Lid Liner, you remove the engine cover & hang it on the open hood using a hole in the underside & it is out of the way. So it saves you from having to set the engine cover aside. Where it may get damaged or dirty? But if the work-a-round is to remove the Lid Liner to access the hole, Don't you then need to set aside the Lid Liner? Doesn't that defeat the entire purpose? Why remove & set aside the LL in order to avoid setting aside the engine cover?
What am I not understanding here?
#59
We can certainly look at it again. I will say we offer replacement clips, at no charge, if yours become frayed over time. The liner itself will not be affected. It is rigid enough to withstand much more than R&I and your tech can have it off in about the time it takes to open the hood.
#60
I think only a small percentage of owners even know that the frunk cover has a hanger and an even smaller percentage use it. I think most take the cover out and put it on the floor. I drilled a hole in the LL and use the hanger only about half of the time - the other half, cover is on the floor. I've seen the same for service techs, some use the hanger and others just take the cover out and put it on the floor
