Which plenum?
Which plenum?
Hi All,
I saw the GREAT video on the plenum installation.
https://www.ipdplenums.com/products/...-dfi-carrera-s
Is there a better one?
Im about to do a servicing and thinking i might do this also...
Hi All,
https://www.youtube.com/watch?v=7Gr7yc4yp1M
The difference is subtle - worth it to me... only saw 7hp on mine with just the plenum(no tune) but strong mid and high improvement. "Strong" for NA.
Filters, tune and headers will be the power combo and collectively give you 30-40bhp. Beyond that there's no bolt ons to help with power. FWIW this setup pulls harder than a power kit/GTS car at double digit speeds but the factory power kit pulls harder after 120mph with more top end.
The guy in the video is good intentioned.... but he's ignorant and the video was hard to watch.
Saw this at 8:13 and stopped.... Who gets a power kit engine cover for these cars that will never be seen? FYI - the plenum will not be an option with the power kit.
His car has a power kit, what does that have to do with his video on replacing the plenum?
If you order a car with a power kit, should you remove the badge because its not visible?
I think its great the person shared his video of replacing the plenum. I know I could not do it, I also learned it might be faster and better to pay a shop to do it.
Not so sure why you feel its necessary to talk down on this video. Or why you bring up the power kit badge.
I greatly appreciate all the Porsche owners sharing their knowledge.
I don't understand your comment at all.
A power kit car will not work with the IPD plenum. The Plenum in the power kit is the primary source of additional power and has a much more sophisticated design. You'd be crazy to swap it with the IPD. But - he clearly does NOT have a power kit since his video has him removing a plastic plenum.... His video opens by stating the IPD plenum is the same as a GT3... It is not. It is a very much improved version of the plastic one though.
Different strokes... Some of us just can't help ourselves from tinkering. If you are doing the filters anyway then this isn't that much more work. Add headers and a tune and its the best version of a naturally aspirated Porsche. No dip on cam and the car pulls much harder. The plenum alone is a good mod but compounds with BMC filers and tune. Headers are icing.
So, if I'm understanding everything that has been said, it would be pointless for me to install an aftermarket plenum on my 2018 Carrera 4 GTS?
I was considering it, but now I'm thinking otherwise.....
I believe the comment above was for non turbo engines.
Not pointless and if I had a newer car then I would do it. The gains will be better on a boosted engine but not as dramatic as a tune.
There was a dyno test performed here a few weeks ago on a 991.2 Turbo aspirated GTS. The IPD Plenum made LESS power throughout the majority of the power band.
Stock plenum cannot be beat on the 991.2, for now..
Thanks for everyones comments.
I feel the video is GREAT - its does a good job of showing the entire teardown and installation. This gives good insight into what you would only find out after opening the car up. This helps me with confidence and makes things easier. (If i was looking for hard numbers on performance and part numbers i would not watch a user YouTube video -- Thats what books, dealers, and forums like this are for.)
Thanks garfunkle - since I have the sport exhaust and sport plus -- I was actually thinking about the plenum and an air intake - leaving the stock exhaust in place.
I've read that the 991.1 comes with headers? Is that not true?
A
A
also was that test on a non tuned car and would not it require a custom/pro tune to account for diff airflow on IPD plenum ?
