Has anyone seen a tire crack like this?
Definitely replace that ASAP. If it's any consolation, they're pretty close to needing replacement anyway.
Love your polyaspartic floors!
I believe Lex was recommending shaving to the nearest 1/32 measurement. If rears only had 1/32 remaining, I think everybody would recommend replacing both.
Received 5,402 Likes
Originally Posted by 96redLT4
Thanks for the info Lex. I've heard about people doing this. I assume a new 'shaved' tire is the cost of a new tire plus a little extra for the 'shaving'. And shaving to 1/32? Isn't it better to buy 2 new ones when they are pretty worn?
J
J
But first:
What is the DOT date code on the remaining tire?
Are they 295 or 305?
If the tires are near 5 years old, buy two new ones for the rear.
Jim, I bumped a tire thread for you. If your tires are near 5 years old and 295 just buy two of these and be done.
No. You don't shave down to 1/32. You need to measure the remaining tire in 32s or mm. And then order a matching shaved tire.
But first:
But first:
Jim
