What to do when self-healing PPF doesn't?
The VDO sliced up the X-pel Ultimate on the front bumper cover, then bounced up to the A pillar where it gouged the paint in two places and punched a small indent/crack into the windshield.
Were this a pick-up or SUV, I'd probably just send some anonymous curses in the general direction of the construction and landscaping industries and call it a day. But it isn't - it's my beloved 911.
So I've tried leaving the car out to bake in the sun, which is supposed to help self-healing. Also tried pouring very hot water over the damaged area of the PPF, which is also supposed to help.
But months later, the PPF damage is still there. The area isn't big, but it's very visible.
Where do I go from here? p.s., if your answer is "OCD therapy" you might be on the wrong forum.
In your case the area is quite a bit bigger and more complicated, but I imagine your original installer would make you a good deal on replacing it. It can't hurt to ask. Maybe it is covered under the Xpel warranty?!
I don't think the ppf will recover from a tear that large. You'll probably need to replace the panel as others have said.
abrasions, chips, scrapes, etc. that penetrate deeper than the .5 mils, will often leave damage that cannot be “healed”.
best left to your installer to make the final call. I wouldn’t use any heat guns if I was a diy
My 997 Turbo had the entire front end covered in PPF. It seemed like a great idea until it began to discolor and peel at the edges. This is the reason that I was a bit more conservative with PPF on my 991 Turbo S.
